Bandsaw Blade Welding
Kevin French, Antrim, NH
>Does anyone have a link for home Welding of Bandsaw Blades? I have a bunch of mixed blades, and want to make some for my saw.
Re: Bandsaw Blade Welding
Dick Coers
>I bought a silver solder kit at Woodcraft to do my blades. I use a stationary disc sander to grind a 45 degree skive joint before soldering. I put the blade stock back to back, and hold it against a board I have added to the miter gage. The angle is complementary since both ends are sanded at the same time. I use plenty of flux, and cut a piece of solder and place it on the band. Bring in the heat from the back and when the solder flows, I slowly take the flame away. When cool I put a sanding drum on the dremel and sand away the excess solder. Works great. I have a 3/4", 3 tooth blade on the saw now and it is about worn out, no joint trouble.
