Leg joinery question
Dan Mitchell
>I saw a tripod table design I would like to replicate to serve as a base for a statue, but I'm not sure the best way to attach the legs. Images of 2 variations of the table are below, I think I would be leaning toward the more triangular of the 2, since the base of the statue is rectangular. I've cropped out most of the leg length, the stand would be about 36" tall. Each top is 3 pieces, with 3 straight legs, and all 6 pieces are joined only where the legs contact the top pieces. I can imagine having 2 dowels running through the legs at 90 degrees & into the top portions where the pieces intersect, I'm wondering if anyone has any other ideas or suggestions, including the best way to execute the dowel idea. I also have one of those "beadlock" jigs which I've had some success with & which might be used, essentially using the bead stock rather than dowels.
I'm also open to other ideas for a "modern design" statue base about 3' high, if anyone has ideas/pics/links.
Thanks
Dan
Re: Leg joinery question
Henry (Raleigh NC)
>Dan - I don't have any ideas for you, but I do find it difficult to imagine the assembly of the 6 pieces shown if there are dowels perpendicular to the legs. Won't that last piece (or leg) be rather difficult to bring into position? Maybe I'm not imaginative enough.
Are those pictures or renderings? I like what I see there.
Henry
Jesse Cloud
>Hey Dan,
Very interesting design. I sure wish we could put some joinery in the middle! That would definitely be the weak link.
As for attaching the top sections to the legs, I would use floating tenons that go all the way through (e.g., a through mortise in the leg, mating mortises in the top sections. You will have to do all the joints at once, tightening each in turn until they are "home".
HAH! Of course!
Dan Mitchell
>I hadn't even thought of that!
See why I need you guys... ;-)
DAN
Re: Leg joinery question *LINK*
Dan Mitchell
>Yes, maybe if there were enough play you could get all 6 pieces into position. I agree, it would be much stronger with something in the middle, I actually saw one of these "in person" at a local art gallery, the joints are only at the legs. Not the strongest, but a very interesting design & certainly up to the decorative/static task of holding a piece of pottery or a statue.
Another possibility may be a perpendicular member through the upper portion of legs set into recesses in the under side of the top, which would be easier to assemble. Unfortunately, I didn't think of LOOKING THERE when I say the piece in the flesh ;-/
Since the base of the statue I would make this for is rectangular, a 4 piece rectangular top variation might be best, though it still leaves the joinery issue.
I should give the original some recognition here, below is the maker's web site.
Dan
http://home.att.net/~gary.leake/
How about a sliding dovetail
Neal in San Jose
>A verticle sliding dovetail would make assembly easy, even if the joints will be a little challenging to cut. I'm thinking a router and a jig of some sort. The dovetail will lock everything in place, and be about the strongest joint I can think of for this application. You could do it with loose tennons, but to be able to get it together, I think they'd have to be cut on an angle so that the tennons in opposing legs would be parallel. I doube that if you had enough slop to get the tennons together, that there would be much strength left at all.
>Haunched tenons in stopped dadoes on the side of each leg inserted from below. Provides good glue surface and prevent rotation of the joint.
mm
>I would try cutting slots through the top parts about a 1/4" deep to capture the legs and then cut square or rectangular holes through the legs and matching slots in the tops so that a floating tenon could be inserted through the legs and then the leg inserted into the tops form the bottom. I might also make a round disk to insert into the points of the three top pieces.
Re: How about a sliding dovetail
Dan Donaldson
>I think that is what I would try. With a dovetail on each side, it should be pretty strong, and it would be basically invisible.
David Katz
>It looks to me like he did it with dowels set into holes drilled in each of the three top pieces. The legs would have holes slightly oversize. And could be properly positioned using spacers.
Robin Corell in Atascadero, CA
>Triangular tables can be more difficult than square. I have attached a pic of one I made so that I can refer to it for the joinery. The central urn shape is actually made up of 7 pieces, the top and 3 sides each of which has a seam at the bottom of the cove. There is a short stretcher extending from each joint of the urn, this is housed in a mortise with half being in each of the adjoining pieces of the urn. There is a dowel extending through each of the upper stretches into the adjoining half of the urn. This is essentially exactly what you have with your project. Only in my case instead of legs the pieces are short stretches connecting to the legs. The key is to glue each to a section of the top in one step and then glue them all together in another. In the final glue up all the pieces have to be brought together at the same time.
The first table I built like this also had a vertical biscuit in each joint of the urn. I found this to be too difficult to cut, the tree legged difficulty factor again. I decided on subsequent tables to add an inside corner block instead.
The other joint detail that would work for your project is the same joint that Sam Maloof uses on the rear legs of his rockers.
Leg bone connected to the Hip Bone
Dustmaker Mike
>come on now you know you want to sing along the Hip Bone is connected to the
Dan Mitchell
>A very beautiful piece Robin. To my eye, it has a unique, almost Egyptian look with Art Nouveau proportions. What is the species?
Thanks for all the suggestions. A sliding dovetail is a good idea, but beyond my current level of expertise, I'm afraid. I think I will go with a 4 leg/rectangular variation, attaching everything from underneath with a tenon across/through the top of the leg, set into a recess in the bottom of the table top. This seems most straightforward, and I *should* be able to pull it off with my current skill & tool sets!
Thanks again for the great input.
Dan
>The wood is some very curly claro walnut with a piece of curly crotch for the top. The bit conecting the lower streatchers is sterling silver. I curently have #3 & #4 of an edition of 10 under construction in my shop. Unfortunately I have a par of silver chests, a bench, a tea table with four stools, and a bed that all have clients and the little tabels are spec so I will have to wait till I get uncommited shop time or untill they find clients.
Triangular tables can be deceptively dificult because the angles are not standard dents on tools. In some ways I think this can add to the appeal as we all tend to like a challenge. Keep a triangular table on the drawing board for a future project they are very satisfying to complete.
Robin
