Drying holly
Drying holly
Drying holly
Andy in Raleigh
>Yeah, I've read some of the horror stories. Here is my story so far:
The other day while riding bikes with the kids, I notice someone has just taken out a holly that got too big. The trunk was about 8" in diameter and there are a few decent sized logs. So I came back and trimmed branches off the 4 biggest and took them home. I immediately sprayed the ends with some clear sealer. I don't have the proper tools for slicing boards, so I posted an add in the tool section of my local Craigslist offering to give someone the logs if they will give me back a few boards and keep most of it for their trouble. I got an offer right away and took them over the next afternoon, which was yesterday. We sliced a log into roughly 1/2" boards (my needs are small; I will get to that) and I took them home. Last night I dipped the ends in some industrial exterior latex paint (goes on really thick).
My needs for the wood are to make frets for historically inspired string instruments (citoles, rebecs and the like) for which I need pieces not much bigger than a match stick and I might use some for inlay and binding. Seems odd to talk about "resawing" stock that is already about the size of a bench slat, but I will.
Anyway, on to my questions...
Should I go ahead and take a slice off of a board and cut up some frets? It seems like they would dry a lot faster that way and maybe be less prone to having problems. I know I would have to over size them to account for shrinkage.
Should I take a few slices but leave them as "boards" (I am thinking 1/2" x 1/4" strips) to dry?
Should I use any heat and or forced air in the drying process? I could put a board or two next to an air return pretty easily.
Thanks!
Andy
Re: Drying holly
Re: Drying holly *LINK*
>I think 1/2" would air dry pretty rapidly indoors, especially this time of year. Pieces of holly and other woods I intend to use quickly I set behind my wood-burning stove where they get constant, gently heat. I suspect the air return idea would dry quickly, even for 1/2" thicknesses.
There was some discussion about drying holly recently on the turning forum - you might search there. Also, search http://www.woodweb.com for something like "drying holly" for good reading.
I've dried small pieces using the microwave technique. Most of what I have now is in turning squares from 1" to 5" or so square which I'm letting dry slowly. People say the biggest problem is with grey staining, but I've been told by someone with experience that holly can be bleached easily if stained.
BTW, you can use the oven-dry technique to measure the MC or just weigh the pieces periodically - weigh a sample piece, dry completely in an oven, weigh again, then use the MC formula: (wet-dry)/dry.
some interesting reading
Re: Drying holly
Re: Drying holly
Rob Stokes in North Vancouver
>Holly's not a friendly wood to dry and the problems will manifest themselves on one of two ways. First, the wood likes to pretzel when it dries and unless it's heavily weighted, will probably twist up. that may not be a huge problem for you as you're using very small pieces.
Second, there's a fungus associated to holly that will turn your wood blue. It's almost impossible not to have this occur when you're air drying it and even when the wood is kiln dried there seems to be a better than 50% chance it'll discolour. I've never been successful in air drying holly and keeping it white. Again - it may not matter for you as you're using small pieces and you may be able to cut your way around the staining.
We've had success with holly exactly once. It was an extraordinarily large tree (approx 16" to 18" above the bell) that was given to us. all we had to do was remove it. The instant it was down we sealed it with a log sealer (available through Lee Valley and other places as well. One of the other forum participants here has an old incubator that will hold wood to 36" lengths. He cut it to length, sealed it, milled it with an Alaskan mill, stickered the heck out of a charge, wrapped it with many of those nylon cargo-holding ratchet-type straps tightened as tight as they'd go and set it in the kiln on low temp for about two months, taking care to monitor it regularly. The wood came out straight, dry and white.
Rob
Re: Drying holly
use a microwave
Robin Corell in Atascadero, CA
>One of the things I often do with a new species of wood that I have milled is to cut a limb into 1/4" thick slices and then dry them in a microwave. By sliceing a limb I am able to get both quarter sawn and plain sawn boards so I can see how each will respond during the drying process. I actually cut the thin boards into a spatula shape so it has some use afterwards.
depending on the type of wood and the moisture content the time for each cycle varies and usually ranges from 45 seconts to a minute and a half (1000w microwave oven). I also like to take a few of the pieces out while they are piping hot and bend them. this tells me the suitabiity of the wood for steam bending. I mention this part as you may wish to try applying force to flatten your boards.
I have not done any microwave trials since purchasing a moisture meter. I let the wood cool down between cylcles still it is cool enough to touch with out a pot holder and then cycle it again. Once the wood stops emitting steam during the cycle I count it as dry, or dry enough. For your use you may wish to further aclimate the wood to your shop.
I have never microwaved wood thicker than 1/4 but I do know it is possible and is beig done in Australia.
Robin
Re: Drying holly
My two cents on holly drying
>You need to get the sawn pieces into a dry environment right away, or the color will turn blue. Seal the ends well and make sure you don't leave any pith in the blanks or cants or whatever.
Second, holly shrinks really unevenly when it dries, so if you cut it into tiny pieces to start, I would bet you will lose 100% of them to twist, warp, bow, whatever. I have sawn holly into 1/2" thick (or thicker) planks, without the heart, and they have dried however their little hearts desired, which wasn't always flat, but at least there was enough thickness there to flatten it and get whatever size pieces I wanted out of it. Let it dry until it stops moving and then you should be okay.
I am not convinced about drying holly with weights or constraints unless you intend to use it in approximately the dimensions you are drying it. In other words, once you open it up again to resaw or redimension it, it could well decide to move back to its most comfortable dimension.
Ellis Walentine, Host
Re: Drying holly
Dale Lenz
Re: Different thoughts....
Dale Lenz
>Assuming holly stains blue/gray based on other woods, such as SYP. The two things you can do is: get the shell of the lumber dry quickly or dry the wood with temps below 50*F. The stain/fungi(?) needs > than 50*F to grow and moisture, eliminate one of them and your good to go. Trying to dry branch wood holly will be a challenge and working could be a problem, reaction wood out the rear.
I have dried a few holly boards, no blue, but did get some cupping, small logs, no pith. 6-8".
Good luck,
Dale
Re: Drying holly
Thanks all!
Andy in Raleigh
>My little holly boards are sealed on the ends and are in some semblance of a press; I lashed together a couple of plastic coated wire shelves with the boards in the middle. They are suspended in close proximity to an air return. Now I guess all I have to do is wait a few months.
