Good ole Delta
Good ole Delta
Good ole Delta
Jim Runchey
>A week ago I posted my problems finding a belt and a set of knives for my 22 540 12" planer. None of the internet suppliers had the belt, unavailable til 3/25. I called Delta direct and they never heard of the part nos. for the blades or belt. I then remembered a tool store in suburban NW chicago, Berlands House of Tools. I called them and they had both. We were going in to visit our kids in the area, so I picked up the two items. When I got back home to western Illinois, I found the blades, in the factory packaging intact, marked with the right part no on the package, printed "for 12 Delta planers" They measured 12 1/2". Now I have the fun job of trying to cut off 1/2".
Re: Good ole Delta
Re: Good ole Delta
teflon_jones
>If you cut off 1/2", I would think you'd end up with one end of the blade that will never cut right. You're also risking bending the blade. Are the blades that are backordered the same ones that you bought? I would try to talk to somebody else at Delta about this.
Re: Good ole Delta
Re: Good ole Delta
Phil Joines Krum, Tx
>Should be easy to cut with either a Dremmel or air grinder with an abrasive wheel.
Re: Good ole Delta
I'd try to exchange them
>Don't those knives have milled slots that register with pins in the cutterhead? Cutting 1/2" off would render them useless.
I could be wrong on this, but I'd check to be sure.
Re: Good ole Delta
Re: toolsforless has those parts in stock
Joanne near Dansville, NY
>Jim,
In December I bought two new rollers for my 12" delta planer # 22-540 @ www.toolsforless.com
I did a quick check on their website and it looks like they have the
knives in stock for $29.98
drive belt $19.88
Joanne
Re: Good ole Delta
Stuart Hough
>Maybe my Alzheimers is kicking in, but I thought the 22-540 WAS a 12 1/2" Planer.
Re: Good ole Delta
It's a 12" planer
Re: Good ole Delta
Joanne is right…
Rod Peterson -- Ormond Beach
>The 22-540 was a 12" planer—the 22-560 was a 12½" planer. I don't know what the 22-580 uses. Those are all the Delta lunch box planer models.
I had a '540 and well remember the distinction when the '560 came out.
Rod
Re: Good ole Delta
David Yoho
>I have the 540 (12") and the 580 (13") planers and an extra set of new knives for each. I was in the local PC/Delta service center last week and saw they were getting $40 for the 13" knives! Sure glad I have that extra set!!
David
Re: Good ole Delta
Aren't the 540 knives double sided?
Dustmaker Mike
>I will have to llook when I get home to see but I am pretty sure the 540 knives are double sided and the 560 knives are not. I have seen the 540 knife sets at the BORGS around here for around $25. I still have the second set that came with my 540 when I got it I can look at the numbers tonight when I get home if you like. As for the belt I have no idea but the little gears on the side of the unit I have an extra set because I had one brake a few years ago and bought two sets just in case.
Re: Good ole Delta
540 & 580 are double-sided
David Yoho
Re: Good ole Delta
The 540 knives ARE double sided?
Bruce, a MN Galoot
>at least one mine, they are.
bruce
Re: Good ole Delta
So are the 560/TP400
Denis Ch�nard, Orl�ans, Ont.
