Need help with my jointer!
teflon_jones
>I recently got a Delta DJ-20 and was working on the wiring tonight but I'm not sure if I'm doing it right. I'm re-using a 220V circuit that has 4 wires, but the plug only needs 3 wires. The instructions on the plug say to connect the hot wires to either side and then the ground to the green screw. I have a black, red, white, and bare ground in my wiring coming from the panel. The instructions are clear and easy on connecting the red and black wires to the screws on each side of the plug, but I'm stuck on the ground. I have both the white neutral wire which is also called a ground, plus the bare wire ground. Which one do I connect to the green ground screw?
I think I connect the bare wire, but I'm not sure. I don't want to fry my brand new jointer! I don't think the white wire gets used in this setup and I think I need to just stick a wire nut on it and cap it. The plug on the jointer looks like a standard grounded plug with two flat pins and one round pin, except the flat pins are rotated 90 degrees. For anybody unfamiliar with this setup, that prevents you from plugging it into a 110 outlet. In most 3 wire 220V setups that I'm familiar with, there's no bare ground wire and there's three flat pins and no round pin, so it's easy to wire it.
Thanks in advance for any help!!!
