sanding can be slow
Bill Tindall, E.TN
>I suspect you will discover that sanding away the burns will be slow. On the end grain I would start with 100 grit. Scratch marks are removed by progressing to finer grits until the scratches are insignificant- 100, 120maybe, 180 and 220( if needed).
If possible it would be best to remove them by making another very light cut on the panel. Light finish cuts won't burn unless you stall the cut in one spot.
I trust you are using a sharp quality bit. Cheap, and therefore poorly ground, bits are more prone to burning. End grain is especially challenging for cheap bits.
