Thin panel clean up.
Bob in Green Bay
>I have a small problem. I have bookmatched some nice cherry panels as door insets. They resulted being about 1/4"+ in with. Ok as they stand as individual pieces. When I glued up the bookmatched pieces to make 12" panels (wide), I have an ever so slight misalignment. It always happens no matter how hard I try and how many jigs I make up. Anyway - it is ever so slight but none the less a blemish with a slight glue seam (on top only) and this will be front and center on my project. I did finish sand one side, hoping to avoid alot of work after glue up.
Do I run them through the planer and just skim off the difference? Then of course all the sanding. Starting to worry about the thickness a bit here and long term durability.
Do I just try to sand out the "rigde"? This seems like cheating and won't be flat.
Any suggestions?
Bob
Re: Thin panel clean up.
Ed Mulligan, Cape Cod
>Bob,
I would flatten the panel. If it's not flat it will look odd when light reflects off the surface.
Maybe you can rip it apart and reglue?
FWIW I try to leave a little extra thickness in glued-up panels so any misalignment can be removed and the desired final thickness is still achievable. That said, anything beyond 1/4" thickness will be strong enough for most panel applications.
Ed
>Bob,
Forget the planer. Hunt around for someone with a drum sander; go to a pro shop if you have to. Don't forget to shim under the high side the thickness of the off-set when doing the first flatening. I would do the front first and then check your remaining thickness. You might decide to "fudge" the backs. Since getting a Performax, I routinely leave extra meat on the panels that I know will have to be taken down to get a truly flat surface.
mm
slashdev
>Grab a card scraper! Unless the offset is greater than 1/64", it'll take just a few swipes. I always have an extra 0.01 in my grooves, so small offsets in the panel don't make it too tight in the frame.
HTH!
Stanley #80 to the rescue
David Yoho
>This is the time I pull out my Stanley #80 cabinet scraper. A few strokes along the ridge and you're done. Nothing beats a well-tuned cabinet scraper for tasks like this one.
David
Robin Corell in Atascadero, CA
>It only has to look flat, not necessarily be flat to .0XX" tolerance. a scraper is likely to be the tool for the fix. On book matched panels the grain in one of the boards is often running oposite to the other and requires the scraper to be used at a skewed angle to the grain.
Robin
