Biesmeyer Fence Out of Alignment
David Katz
>My Biesmeyer fence has about a .0005 (five-thousandths) concave section it the middle. On each end (the front and the back of the table) I can easily align it with the miter slot. However, as I move the dial caliper along the fence I notice the concavity.
Should I replace the fence?
Thanks...
- David
Re: Biesmeyer Fence Out of Alignment
Rod Peterson -- Ormond Beach
Well, either you mistyped or misread. .0005 is five/ten-thousandths, not five one-thousandths. I think I read somewhere that machinists would call that five tenths. That's ten times better than how you spelled it out, and if it's true, I'd leave things alone. Frankly, I'm not sure how excited I'd get even if it was five thousandths (.005).
Rod
David Katz
>Sorry...I did miss-type. It is .005.
Re: Pieces of paper
Peter Gregory
>Correct a minor problem like this with a single or two strips of paper. You can loosen the face, slide the paper in and then tighten again. I fixed the fence on my PM66 that way.
Good luck.
Re: Pieces of paper
Jay St. Peter - SoMD
>Not on a Bies. You can't just loosen the face as the screws that hold it in are laminated over.
I had a similar problem with mine when new, although I suspect mine was more than 5 thous. The end of the fence came out and pushed the piece into the back of the blade, not good. Delta replaced it. Frankly, I suspect the replacement varies by more than a few thous also. My first fence was also welded onto the t-square part cocked such that it couldn't be brought perpendicular to the table.
I think the clones have surpassed the original. Most of the clones are now adjustable in all directions and have replaceable faces.
Jay
Lee Schierer - McKean, PA
>A piece of paper is only .003 thick in most cases. It may not be worth the effort since you are working with wood a material which will change that much in width from a dry to a rainy day. My Beismeyer has the screws attaching the face plates to the main beam buried under the face laminate so shimming would be a problem.
Lee
Tony - Memphis
>I've been using mine that way for many years. I never measured it, I just notice that there is a slight dip in one area. My tablesaw was a much bigger dip that that in the table. But somehow, I manage to make stuff. I think folks are spending too much time measuring the equipment instead of making sawdust these days.
Tony
Gary Evans Tallassee, TN
>Hi David,
As someone else mentioned, .005" is not a lot.
I think I would rip a couple of boards and then match up the cut edges to see how they fit. You may find that what you are measuring doesn't translate to the workpiece.
Gary
