What on earth is this thing???
Jim
>I was in an antique mall and found this object. I don't know what it is and was wondering if any of you have any ideas. Please comment back. Thanks in advance.
Re: What on earth is this thing???
Hand, left hand/with ring????
It's not a dead cat...
>So it can't be a doorstop.
Clint
the picture is too small to see detail
What material is it made from, it might not...
>be from earth. Just kidding, a little more description a couple of larger photographs would help.
Stephen
>Is that an embossed deer at the bottom?
Knurled finger wheel at top or gear?
Something sticking out the top - mechanism?
Any features on the back?
Jim
>There is an embossed deer at the bottom, also on the very bottom is 2 screws,when I took them out I found a small peice of foam rubber.
On the other end on the face it has a knurled knob with a "1/4 threaded bolt attached to it.
On very end of the narrow end there's a whole thats in line with the knuled knob on the face, and beside that is a small peice of metal that has been dimpled twice that matches the dimples in the main body.
When I first saw it I thought it might have been some sort of old chalk box or old reload container for black powder rifles but once I got it home and was able to check it out in futher detail it's quite evident that it's neither one of those two things.
Again thanks for the head scratching that you all have been dong so far,
Jim
>Better and more pictures would help. It's hard for my old brain to understand the orientation and details of the features from your verbal description. How can a hole on the "very end of the narrow end there's a whole thats in line with the knuled knob on the face" - would not the surface of the very end be oriented 90 deg to the axis of the knurled knob?
I've attached a blowup of your original photo with a bit of image enhancement in case someone else can guess.
From the photo appears to be a hand grip of some sort. The embossed deer makes me think it is related to hunting (detachable gun grip, part of a meat grinder?) Related to photography? A 1/4" bolt is commonly used on camera and flash equipment, however the orientation seems unusual if it
Re: Bow counterweight?
Brian in Brighton
>Is it a counterweight for a compound bow? Looks like a possibility.
Brian in Brighton
