cope and stick question
les winter
>I read somewhere that it is common to run all the sticking through a shaper or router table and make the coping cuts later as needed. Well, I tried this using maple for the sitcking for 4 doors for laundry room wall cabinets I am building. I ran a scoring cut, 1/16" deep and then a full depth cut with little chipout.
When I went to make the cope cuts, I realized that the backing board didn't match the profile and allowed significant blowout as the cutter reached the trailing edge of the board. Fortunately, this is a Shaker profile, and I was able to mill a board with the reverse pattern and save the stock.
Is the method I used the normal way this is done?
thanks.
Les
