Foam Brush for Shellac??
Cody Lewis in LV
>I have always used a foam brush to apply poly because for me it has been easier to get a smooth finish without bristle lines - and because they are so cheap. Today I'm going to be using shellac for the first time ever. I was planning to use a foam brush like I'm used to, but I saw in WalMart a little sign next to the foam brushes that said you should not use them to apply shellac or lacquer. That really surprises me. Anyone know why? Is there really a problem using a foam brush to apply shellac?
Re: Foam Brush for Shellac??
No. Cause *LINK*
>Alcohol or lacquer thinner will attack and dissolve the glue that holds the "brush" on, or the foam itself, or both.
If you're brushing shellac (easier to "pad" in on), use a high quality hair brush and add a few drops of pure gun turpentine to your mix. The turps acts as a retarder and give the shellac more time to self level out the brush marks. You cannot work this finish like you do poly.
If you'd like more info on applying shellac by hand, go to Jeff Jewitt's site at the link and click on Articles.
Homestead
>Good Afternoon Cody,
Use a natural(ie, flagged) bristle brush to lay on shellac, or a soft cloth and wipe it on.
George
all about foam "brushes" and shellac
Bill Tindall, E.TN
>I thought I had discovered "sliced bread" when I found that I could apply shellac with a foam "brush". I hadn't read the directions. Indeed, it worked for a spell, but upon prolonged exposure the foam disintegrated. Made no sense to me as a cured urethane foam should be stable in any solvent. Must be the black foam used in these brushes is not typical urethane.
So, I made a brush from some upholstery urethane, the yellow stuff. I found later easier directions for making these brushes in the latest Fine Woodworking. My home made yellow urethane brushes did not dissolve. And one you use one for shellac you will go ...Eureka!
You can wrap the used brush in plastic kitchen wrap and keep it alive for several days.
Steve Schoene
>Bill
If your urethane isn't attacked by DNA why not just soak the foam brush in alcohol to revive it. I always leave my Taklon gold shellac brushes only partial cleaned so they are stiff and don't collect dust. Then DNA softens them right up when I'm ready to use them next.
question for Steve on Taklon and application
Bill Tindall, E.TN
>First an answer to your question. I have only made one yellow foam "brush" and it was quicker to make than the time to soften a real brush with shellac left to dry in it. So there was not much incentive to preserve the foam applicator beyond the need for the project at hand. I think the letting it dry in the foam would not work well. The foam holds times more material than a real brush, or at least the pricey Taklon brush I have. Hence, it would take considerable soaking to revive the foam. But then one could ring it out before storage.
Now for a question of you..... My Taklon brush was a failure, or my technique was a failure. I would like to know what you do different that led to success with a brush.
I bought a $30 brush from an art store. It is about 1 1/2" wide, maybe 2" long by 1/4" thick and called a "flat wash brush".
Failure mode: If the applicator, be it a cloth covered wool ball, foam or brush, runs out of shellac during a pass down the length of a board I can't reload and then restart this pass without a lap mark. My brush holds so little material that it needs reloading every few inches. Hence, it is useless in my hands for something as long as a foot. The only way I have successfully applied shellac is with an applicator that holds gobs of material- cloth covered wool ball, foam or my favorite, spray it.
Can you offer any advice? The more I use shellac the more fond of it I become. I would like to be able to do small pieces without starting up the spray gun.
Re: question for Steve on Taklon and application
>I have recently "discovered" Shellac. I want to be able to do a better job with it, easier. So I am eavesdropping on the response to Bill's questions.
And, Bill would you explain how you made your foam applicator? How well would it work on a surface like a door with crevases and moldings, etc.?
Flagged? I think not.
Michael Dresdner
>>> Use a natural (ie, flagged) bristle brush
I'm sure George did not mean it to sound this way, but the above reads as though either natural and flagged are the same thing (they are not) or that you must use a natural bristle brush that is flagged for shellac. This is not true.
Flagged is the brush maker's term for what the hair care industry calls "split ends." That means each individual hair splits into several hairs at the end. This happens naturally in animal and human hair. Therefore, there is no point to artificially flagging natural bristles, and I don't know of any brushmakers who do it. Furthermore, the best brushes have uncut ends. That's because animal hair tapers, while some synthetics do not. The taper makes the end of the brush softer, so flagging, while it will happen anyway, is really not necessary on a quality hair bristle brush.
Most synthetic bristles do not flag by themselves, so brushmakers often run the ends through a flagging machine, which crushes the ends of the bristles so they flag.
I agree completely
Michael Dresdner
>Working with a short Taklon brush is great for very small applications, but you are exactly right when you say that no matter how the bristles respond, using a brush that does not hold enough coating for a reasonable size brush stroke is an excercise in frustration.
While a Taklon brush would work if you could find one that is thick enough with bristles long enough, the truth is that the art world has no need for it, so they are rare indeed.
Try using a very soft bristle brush with some thickness to it (to hold more shellac) and longer bristles. China bristle is a bit too stiff for my tastes here, buy an ox hair or ox hair blend works nicely, as does fitch (skunk) and squirrel. Some folks like badger as well, though I personally don't.
Try a foam roller for Shellac
Dave Bair, Eaton Rapids, MI
>For flat work, I use 4" white foam rollers to apply the shellac and a flagged nylon brush to tip it off. The coats go on pretty heavy, but two coats is my limit. After that, things go poorly.
Steve Schoene
>I think there are lots of different strokes... I'm not troubled too much with lap marks. I never touch it down over the just made stroke, but a little off it, that inital touch down is where the heavier "deposit' is made, then I move toward the previous stroke, then back over the spot I touched down, which is still wet since it is only an instant before and then complete the stroke. This gives a very minimal overlap since these strokes with the low reservoir brush are so very thin. Small holidays are also not very significant and, along with any overlaps "average out" in just a few applications. For me the thinness eliminates my urge to want to over work an area--a very big no-no with shellac.
On the other extreme, I see people who do quite well with large mops of brushes for shellac, but for me that would just lead to a heavy spot some where that when I mistakenly touch again ends up with the rumpled mess problem when prior applications start to move along with the brushing. I'm sure if I worked at it enough I could train myself out of that bad habit.
Even with the very thin film from the Taklon brush it still seems to build faster than a padded finish, so that's why I like it. But, this is an area where there seems to be a lot of approaches that work and inividual preferences differ widely.
