>I have been asked to make a coffee table replicating a design in a furniture catalogue. The table will be solid pine 1.5" thick, 4.25' x 2'and is to have solid sides (instead of legs) mitered to the top across the width (envision an upside down square-sided U) I'm a bit worried about strength of this joint - would biscuits be sufficient to re-inforce the joint? Anyone done this?
>For maximum strength the joint could be dovetailed and then veneered to cover up the joinery. Problem is that the joinery will tend to be 'print through' and become visible over time. The secret miter dovetail overcomes the problem, but the learning curve is steeper.
With less ambitious joinery such as biscuits, dowels, floating tenons, I'd add a fillet (a triangular glue block) on the inner corner or perhaps a couple of stout metal straps mortised into the inner corners.
>I made two of these a long time ago. What I did was glue up what amounted to cutting boards made out of 25 1X2 strips in an alternating pattern so that the corner was a massive box joint. Turned out to be very strong. But not as clean and mitered as your design.
How about an arch under the table that would only be visible if you bent over and looked under it? Could be solid, like corner block or even a curve wood slender arch.
Other than that, you need some sort of concealed joint. Dovetails. Splines, dowels. Something.
Given the thickness of the materials and relative softness of the wood, I agree that you need to somehow reinforce the joints. If internal arch(es) or stretchers will not do, and reinforcements must not be proud of the inside surfaces, you could try extruded right angle stock, mortised into and flush with the interior surface. Your surface is thick enough to use screws, and I would also apply epoxy to strengthen the joints over their full length. I'd use right angle stock with the widest possible flanges consistant with visual presentation.
>I was thinking about the angle iron. My thought was to make three or four pieces about an 1 1/2" long out of about four inch angle and mortise them into the ends of both pieces. A right angle tenon. Bed them in epoxy.
Another thought would be to heat and bend some 1/2" rebar to a right angle and make "around the corner" dowels out of them. Drill slightly oversized holes and epoxy to fill the gaps.
>You didn't say, but one thing to consider is the wood movement across the top. I've made a bunch of these over the years and I always glue up the panel long enough that I can cut both ends and the top from the same long panel. That way the grain will match as it goes up one end along the top and down the other end and you have all the grain going in the same direction. No cross grain joint at the ends.
>Steve - that's certainly how I envisaged doing it, from one long panel. What form of re-inforcing did you use on the joints of the ones you made? - Rob
>Splines will be much stronger than biscuits. Or us a mitered lap joint which will look line a miter from the side, but not the top and back. They are far stronger than regular miters, biscuited miters or splined miters.
>You definitely need some way to keep the top and the ends from moving relative to each other when Uncle Festus trips and falls against the end of the table. Biscuits work by providing glue strength to hold the shoulders (miters) together, but they don't have enough surface area in this case to match the strength necessary to pass a reasonable torture test. Plus, pine is soft and the wood itself is likely to give at the stress interfaces.
I have made many items like this, and my standard engineering solution is to glue a stretcher (or more than one) under the top as Lee suggested. This will not be noticeable on a coffee table, and the shoulders at the leg panels will prevent the legs from flexing. The higher the shoulders (and the more stretchers you have), the more rigid the table will be.
Metal reinforcement would also work, but I'd steer clear of rebar. I've used short sections of 3x3 angle iron with great success.
