What is it?
Thomas in AK
>Can anybody enlighten me as to what this plane was used for?
What is it?
Thomas in AK
Re: What is it?another pic
Thomas in AK------WebKitFormBoundaryA3A6+D+BmLEOWw
Re: Molding plane?
>The sole looks like some old molding planes that I've seen. Post over on the Hand Tools side for better ideas.
Re: What is it?
>It looks like it was used to make a groove in a board similar to using a dado head on a saw, only this one uses elbow grease instead of burning coal. The arms on the plane allow adjustment to put the groove a certain distance from the edge of the board. It is used by starting at the far end of the board with short strokes and working your way backwards until you have a full length groove. It will not work nearly as well if you start trying to cut a full length groove along the board. You could sharpen the iron and put it to work the next time you're building a drawer box.
Plow Plane
>Moses got it right. They usually have a set of blades for different size grooves. This type is earlier than the screw adjustable fence, the captive wedges look pretty beatup as they usually are. They can be replaced if necessary, try and keep the originals (if they are the originals) with the plane.
Are they any makers marks or numbers stamped on either end of the plane?
Stephen
Re: What is it?
>Well whatever it is, I just bought it for $20 bucks in on-line auction from a local auction house.
Re: What is it?
>That is an exceptionally good deal. A lot has been written on the use of these in the hand tools forum; search the hand tools archive for "plow plane" and "plough plane" for more than you ever wanted to know ;)
