Out of ideas....
Out of ideas....
Out of ideas....
Edward in Vancouver
>I have a plain-jane Delta TS, and have spent enough time and energy trying to get the splitter positioned just-right. Problem is, the thing is so thin and wimpy it bends. What kind of options do I have to replace it with something that works?
Thanks
Re: Out of ideas....
splitter pin placed in throat plate
MN deepwoods dave
>Something I've read about but haven't implimented yet. Take a dowel, or metal pin, the diameter of your blade (typically 1/8") and position it directly behind the blade in your throat plate. I've made my own throat plates out of MDF. I did this to eliminate tear out, but it would be easy to drill a hole into for a splitter pin too.
I'd be interested to hear if others have implimented this.
Consider a Micro-jig splitter *LINK*
Charles R. Smith
>Micro-jig, the company that makes the much-loved Grrr-ripper system, also makes a simple but terrific little splitter. I have one and appreciate it; it was a Christmas gift from my kids, who wanted me to keep all ten fingers. It's the first splitter I've bothered to use -- and it works. They come in two widths, to match the thickness of your sawblade. You can get them from Lee Valley or a number of sources. No affiliation, just a happy customer.
Charles (who still has all ten digits on his forepaws)
Micro-jig splitter
Re: Consider a Micro-jig splitter
Edward in Vancouver
>Thanks for the replies. Actually I do have one of those microjig splitters but wasn't very impressed with it. In retrospect it could be that my throat plate had a bit--about 1/16" of side to side slop. Maybe I'll make another throat plate and give it a try again
Larry Clinton At Frankfort (Central)., Indiana
>Edward, having read your post about the play in your insert - I think you are fighting a loosing battle. IMHO, the first thing you need to do is correct that issue. I made several inserts for my Unisaw at the same time. I drilled counter-bored holes on the sides and installed pan head sheet metal screws. My saw has "tabs" in the insert opening where the factory inserts have screws that are used to adjust/remove all play. I installed the screws in the new insert in the same locations. I also installed screws in the bottom to level the insert. Once these are installed and adjusted, you can install the Micro-jig splitter. My micro-jig insert works perfectly. I actually purchased a second Micro-jig insert kit for spare inserts. I am not knocking the "homebrew" inserts, its just that the Micro-jig works well and at the cost it isn't worth it to me to design and build my own - although I may in the future decide to try that.
Jerryburns
>Ed I have used the micro jig splitter for about 4 years on both of my saws I just up graded to the new pro 2 splitter on my unisaw it works really well
You Can Make Zero Cl;earance Insert w/Splitter
>Good Afternoon Edward,
I was going to place an order for the Micro splitter until I decided to make on myself. If successful, it would save me from buying an effective accessory which I think is way over priced. I made two zero clearance inserts and kerfed a slot at the back edge of each, the same thickness as the blade. Then I cut a strip with the width of the kerf and glued it in. Works perfectly and costs nothing.
I switched out to a blade which was a bit thicker. I had to re-kerf the second insert by raising the blade through the narrower slot. The splitter still works fine since it remains registered with the right side of the new kerf and keeps the work tight up against the fence.
Try it. You'll like it. :<)
George
Just bite the bullet & get a Bies... *LINK*
Tim Greif - West of Chicago
>I fussed with the stock delta splitter for quite some time and then just parted with the money and got a Biesemeyer snap-in splitter. Check em out at the link below. I've heard of other folks using the same saw bracket and making their own custom splitter shapes out of shelf brackets, though I really don't know why you'd want to do that.
This thing is pretty spendy ($130-160) but the quality is great and the instant on and off is worth it to me. I removed the kickback pawls. Quite honestly, the ease at installing and removing makes me work more safely. Before, I had a tendency to not reinstall the splitter when switching between dado and blade operations.
Biesemeyer Splitter
