How about Poly over Shellac?
Ed Beck
>So I made a bookcase / nightstand out of plywood with a cherry veneer and curly maple for the top and face frame. After applying the shellac to the top I was not happy with the grain, it just didn�t pop. So I sanded the shellac off of the top, but I did not want to try and sand it off of the plywood for fear of eating right through the veneer.
I applied General Finishes Arm-R-Seal Urethane Topcoat semi-gloss to the top and am happy with the effect. But during my second coat I noticed that the shellac finish on the plywood looked very different than the poly finish on the top. So how about applying the poly over the shellac? Any problems with doing this?
Re: How about Poly over Shellac?
Jason Roehl in Lafayette, IN
Not a problem
>Shellac is an excellent tie-coat between finishes. It also works well as a sanding sealer, so poly away over your shellac. The one caveat is that if you are using waterborne poly, you need to use dewaxed shellac before the poly (you can use natural, waxed shellac as long as you put a coat or more of the dewaxed on before the poly).
Jason
Steve Schoene
>Oil based varnish containing polyurethane, a category which includes Arm R Seal, also can have adhesion problems over shellac with wax.
If you have shellac with wax, you could seal it in with dewaxed shellac, with the best method for doing that is by spraying. Brusing and padding can pick-up material from the lower coats, giving a less complete barrier. The Zinsser shellac aerosol cans contain dewaxed shellac.
Alternatively, you could use a traditional resin varnish over shellac with wax.
there's an easier way
Michael Dresdner
>If you removed the shellac from the rest of the wood, why not remove it from the plywood as well? It will come right off with denatured alcohol on a nylon abrasive pad without sanding, so you don't need to fear sanding through your veneer. In this way you will have a consistent look throughout.
