Re: Shop layout
Scott in Montana
>Hello Shane,
I have a 20x22 shop with a tablesaw, a bandsaw, a shaper, a bench, a jointer and so on. No matter what the layout... trust me, you don't have an inch to spare. I have so little room anymore that I am restricted to making jewelery boxes. :O)
Well actually I've done pretty well considering the accumulation of power tools I have. One of the best things I did was to keep almost everything at the same height as my tablesaw; this aids in working with large panels and long boards. Having my jointer at the end of my tablesaw has also worked well. Upon ocassion I need to lay a big sheet on my tablesaw and if I remove the fence from my jointer its bed is level with my saw's extension table. My mitersaw/radial arm saw bench sits on the other end of my tablesaw and again it is at the same level as my tablesaw. My workbench is just an inch or two higher than my table saw and sits directly behind it. My shaper can pull double duty as part of the outfeed table for my tablesaw.
My stationary disc/belt sander, router table, bandsaw, drill press, mortiser,and Panamax sander all line up along the far wall. Thank God for mobile bases! My jointer and shaper are a European combination unit that I have really enjoyed.
There's not much room left on the walls as they are paneled with plywood and hand tools cover most every inch. I still need to build more cabinets to mount high on the walls. Moving out my huge rolling mechanic's toolchest and moving tools to the walls really freed up a lot of usable floor space.
Another appliance I couldn't live without is a thin vertical panel saw I made. Being able to slice up sheets of plywood to more handlable sizes is a real plus.
Another thing you might want to consider is painting the floor a light color to make the shop feel larger. Light colored floors also make finding that important dropped screw easier. And don't forget to plan out your lighting for good coverage.
It's a challenge but it can be done.
Good luck,
Scott
