200+ woodworking book reviews
Oil finish, how to tell if still good. (In can)
Link Van Cleave
>I have some Liberon "finishing Oil". About 1/2 can. Must be a couple of years old at least. I know you can test shellac on glass. Is there a test for oil ? I have new finish ordered but I need to get going on this and would like to use what I have.
Link
Re: Oil finish, how to tell if still good. (In can)
Re: Oil finish
>Link,
Assuming you're referring to Liberon Varnish, your finish should be fine, at least for first applications as long as it's skinned but hasn't gelled in the can. You may have a higher percentage of the varnish resins locked in the skin layer, but the liquid should be ok to thin with a bit of MS or naptha and use. If film durability is a real concern, I'd make the final coat with the new product.
mm
[JMO-YMMV]
If the can looks like this.....
>..... then it's too old ;)
Happy Woodworking!
David Yoho
>If it's oil, I would think it's good still. I don't think it would hurt to begin using it until your new stock arrives. The key is to apply thin coats (not "thinned" coats but thin coats).
simple guideline
Michael Dresdner
>Clear gloss oil finishes will be fine as long as they are still liquid.
Satin or tinted finish is a different story. Here's why.
Oil finishes usually contain driers. Those driers will eventually be compromised by pigments. Flatting agent, used to convert gloss finish to satin, is a pigment, as are some coloring agents. These will, over time, bond with the driers and disable them. For these finishes, test for drying time by putting a drop out on a piece of glass or laminate.
Clear gloss finishes typically do not contain pigments of any sort, and the driers in them will remain good forever, as long as no air has crept into the container.
By the way, the same is true of cans of Japan drier. They never go bad. Odds are excellent that a thirty year old can of Japan drier that is still liquid will work just fine.
