Veritas - Innovation in Tools
Way OT, Starting truck question?
>My son ran out of gas on the interstate in the middle of the night (of course). It was a new Toyota. I took a gallon of gas and went to the rescue. He had drifted out of the road and was on the shoulder with it tilted down on the passenger side about 10 or 15 degrees. Put the gas in and it would not start. Went and got another gallon and it started.
I insisted he limit the amount of "grinding" he did. It was cold and miserable and I did not want to add a dead battery to the mix. Now I am wondering. Someone mentioned we should have turned the key on for a minute or two and let the fuel pump do its thing and it would have started. What procedure should we have used?
NOT a CAR GUY
Re: Way OT, Starting truck question?
Sean Troy
>Fuel injection requires priming before it will start when empty. Turning the key on for a minute is supposed to prime the system from what I've been told.
Ron Hildreth
>Barry,
Keeping in mind that on most of the new vehicles now days, the fuel pump is located in the fuel tank itself. It takes at least a few minutes after turning on the key, for the pump to pump fuel to the injectors, and also fill the return line back to the tank, insuring that the pressure at the injectors is reached to get the proper spray pattern, thus making it easier to start. This is also the reason you don't want to pump the throttle pettle before starting a computerized vehicle. It confuses the computer!
Ron in Iowa
Stuart Hough
>One other thigs is that even though the fuel lines are relatively narrow, it takes quite a bit to prime the system, and it might take more than a gallon to get it ti the level where i will start. Some cars have sensors that won't allow the car to start if they sense any cavitation at all. As for letting the key stay in the Run position for a few minutes, it only take 3-4 seconds to bring it up to pressure--if the fuel level is adequate. If the pump is cavitating (air bubblng inside the pump) then it won't prime , no matter how long you leave it in Run.
John_in_Az
>The pump does need to prime and pressurize the injectors in order to start. This should only take a few seconds, probably less than 10. Depending where the fuel pick-up is located inside the tank I think the 15 degree tilt made one gallon insufficient for the fuel to reach the pick-up. One gallon of fuel spread around the bottom of the tank probably only amounted to 1/2 inch or less, and tilted to the side still left the pick-up dry. John
Larry Clinton At Frankfort (Central)., Indiana
>Barry, most new vehicles have a sensor that shuts off the fuel pump in a few seconds when no vacuum is sensed. This is done so that in the event of a wreck the fuel pump does not continue to pump fuel causing a fire and or explosion. When a vehicle runs out of fuel, the lines are drained. Turning it on and leaving it on will still only allow the pump to cycle for a few seconds then lock out until reset. In order to re-prime the system / (fuel rail on ejection systems), you must turn the key on for a few seconds (10 or so), then OFF to reset the computer. Then repeat the operation 4 or 5 times. Then start the vehicle.
Jason Roehl in Lafayette, IN
I agree, here's why.
>I am now on my second Ford truck with dual tanks. My normal running procedure is to run one tank dry, switch to the second, run it down, then fill both and repeat. When I say I run a tank dry, I mean I run it until the engine starts to stumble, meaning there is air in the fuel lines. When I get back to that tank (sometimes I switch back to it at the gas station), the truck will still start instantly. On Ford trucks, the in-tank, high-pressure fuel pump (what most EFI vehicles have now) will run for about 1-2 seconds then stop when the ignition is turned on, then start again when you start the vehicle.
Anyway, I told you all that to tell you this. EFI vehicles typically use a recirculating fuel system--the fuel rail is pressurized, but the fuel pressure regulator keeps the pressure within a certain range, and there is/are a return line(s) to return the excess to the tank(s).
I'm going with the idea that since the vehicle was on a slope, there was not enough fuel in the tank to reach the fuel pump intake screen. 15 or so feet of 1/4" fuel line is about 8.8 cu in, or 0.038 gallons--not much gas to prime the fuel line. And, if you've ever dropped a gas tank to mess with the in-tank pump, you'll find they're quite small (about the size of your fist, including the motor).
Jason
Ditto: this is the right answer
Grant Smith
>You need to turn "on" the ignition, let the fuel pump pump for the few seconds that it will before the computer shuts it down. Then turn the key off, wait for up to two minutes (depending on the make and model) for the computer to reset, then repeat the process. it should only take a couple cycles of this at most to prime the fuel rails such that the computer will allow spark ignition to occur.
You were right that grinding the engine has no benefit. I also agree that maybe the angle of the vehicle came into play on why 1 gallon wasn't enough.
Note that on todays multiport fuel injected cars, it is NOT good to run them out of gas, this can dislodge crud in the fuel filter and cause injector clogging.
FWIW,
Grant in Iowa<---not a mechanic, but one of my friends is and he's always schooling me on these things.
One other thought
Lee Schierer - McKean, PA
>In addition to the earlier replies you noted that the vehicle was tilted. The gas pick up is usually in the center of the tank, surrounded by a small reservoir type baffle. If the tank was emptied on level ground and then filled on a hill, it might take more than a gallon to get fuel to the level where the pick up tube would see it. If your car is equipped with a low fuel indicator light, sometimes the light will come on when running up hill for an extended period of time only to go off when running downhill (or just the opposite depending on the make of car)
Your mileage may vary.
Lee
