OT - Moen faucet sprays water at me
Carol - now in NC Nebraska
>Need help with fixing this faucet. It is a lever type kitchen faucet. Swing lever to adjust temperature. Lift lever to turn on. Swing spigot to get one sink or the other. The water sprays out from the very base of the lever/spigot pedestal.
Oh! And I HATE plumbing and I have NO plumbing related tools here.
Suggestions?
Re: OT - Moen faucet sprays water at me
Bad faucet ! Bad ! Go to your room.
Ray Carson - Lawrenceville, NJ
Al Stokka - Cambridge, Iowa
>No plumbing related tools? I ain't buyin' that. You have a philips and a straight-blade screwdrivers adn a crescent wrench or channelock pliers, right? Then you have all you need. OK, a roll of paper towels will come in handy too.
Moen faucets come with a lifetime warranty. Call 800-289-6636 and describe the problem. They'll send a repair kit which you can install in just a few minutes. They will include a pouch of silicone lubricant that will make the faucet operate just like new.
Al
Ken Oakley-Sunny St. Cloud, Fla
>I have the same problem with a Koehler faucet. Paid big bucks for it and a Koehler sink, plus more big bucks for a plumber to install. It was still under warranty, when it first started leaking, so I contacted Koehler. Their response was a repair kit, probably worth $0.79. When I asked them if they would cover the plumbers charge to install the kit they replied their warranty covered parts only. I replied Koehler must mean CRAP in German. Too bad Honda doesn't manufacture plunbing fixtures!
Ron Hildreth
>Hi, Carol !
Got a good suggestion, and the one I follow faithfully - Call the local plumber!
Can ya tell, I'm in the same boat you are! I hate plumbing!
BTW---HAPPY VALENTINES DAY !!!!!
Ron in Iowa
Wait a minute, Al -----
Ron Hildreth
>I don't remember any plumbing tools in your shop the other day!!!
Hehehehe!
Ron in Iowa
BobP
>Carol,
I went through this exercise a few months ago. I got the O-ring kit at Home Depot. It is not too difficult to effect the repair, just remember how the insides come apart. For my faucet it was a matter of replacing the O-rings. I had some silicone lubricant that I applied to the O-rings (I think a wise thing to do). Solved the leaking problem. Mine would leak real bad when the spigot was swung side-to-side.
I seem to remember using only a philips head screwdriver to do the job.
Good luck
BobP
One suggestion
I have that brand
Bri in Mtl
>Did you make sure that the hoses are fully engaged underneath? They sort of "click" when properly engaged -takes a little bit of muscle.
Pull out the pullout section and see if it's leaking where the faucet head screws on to the flexible pullout hose -when you screwed it together did you feel the washer compress a little? I had to return 1 unit cause it was leaking there.
HTH
Re: Faucet update
>I pried the little cap off the top. It needs an allen wrench. Don't have the right size here.
There is no pull-out sprayer. This is the faucet itself.
The good news. Someone is coming tomorrow to fix it. He says it needs a new 'kit.' Have at it, my man. I'm gonna go do hospital calls. Much, much easier than plumbing.
Did I mention I HATE plumbing?
Re: That's because...
>...the plumbing tools are in the basement. I hate thinking about plumbing and keep the related tools out of my sight. ;^)
Al
Warranty ?
Yonak
>My Moen faucet has a lifetime warranty. They have sent me replacement parts after I explained the problems to them on the phone (800 531 1602) .. no hassle .. no charge.
Re: Warranty ?
del schisler
>sometime's you need the moen puller they are in their real good Their is a brass clip that need's to come out before the cartrage will come out wareanty for lifetime Get the number off the cartrage or match it up at one of the box store's
