Re: Slightly different approach
Dave Mount
>This is no different from a frame and panel door, so you could orient the grain parallel to the drawer sides as long as you left enough residual depth in the grooves in the sides to accommodate expansion. Using rabbets or a panel raiser that forms a flat tongue will discourage the bottom from wedging into the sides and potentially splitting the bottom shoulder of the groove off.
However, I run the grain the other way, parallel to the drawer front. This sometimes makes for a greater length of cross grain movement (since many drawers are deeper front to back than they are wide), but you account for expansion by changing the way the drawer is put together. The drawer back is cut so that only comes down to the upper surface of the drawer bottom, and the bottom is left long so it sticks under the drawer back. The drawer bottom is not attached at the sides or back, but is glued or tacked to the front of the drawer so it is held in place at the front and can't slide out. Expansion of the drawer bottom just runs out under the drawer back and doesn't hurt anything, no matter how much it expands. If it were to expand so far as to protrude inconveniently behind the drawer, just plane it off.
Easy, it works, and there's no chance of splitting anything.
Dave
