Drawer sides
Drawer sides
Drawer sides
Joe in a Cleveland suburb
>Hi.
I have a small table with a couple drawers. Just about done with this little project.
The DT'd drawers are made from poplar and slide on the wood rails.
Should I put any finish (shellac) on the drawer sides? Sometimes I do, sometimes I don't.
I know about the finish smells in drawers and food and clothes and so on.
This little table is Shaker inspired in its look.
I am voting 'no' on the finish. What do you folks think?
Thanks.
Joe
Re: Drawer sides
Re: Drawer sides
John Pappas
>Joe, I am also building a small table with two drawers. For what it's worth, I plan on applying SealCoat to the drawer sides and bottoms. No odor with shellac.
Re: Drawer sides
Re: Drawer sides
>Good Morning Joe,
I'd also use shellac on the sides and bottoms. Water based poly may also be an option because it doesn't impart an odor.
George
Re: Drawer sides
Re: Drawer sides
>Joe, I would dilute some blond shellac or Seal Coat to about a 1# mix and coat the drawers with one or two brushed or wiped coats of that. Then, give all surfaces a gentle scuff sanding with 320 dri lube paper and finish with a coat of a light colored paste wax. This combination gives adequate protection from dirt and fingerprints and it won't stink up the carcase.
I like to use really thin shellac for this because it doesn't tend to lap or streak or build unevenly like shellac straight from the can.
Try it. See if you like it.
Re: Drawer sides
a yes vote, and more on fitting
Bill Tindall, E.TN
>look at old pieces with traditionally unfinished drawer sides. The wood looks dead and grungy as a result of oxidation and dirt accumulation.
I shellac drawers inside and out. They look good and slide especially good. Apply about a 1.5 pound cut with a rag. Sand smooth and apply one additional coat. If you rub this coat out with steel wool and wax the drawers will slide like they are on ball bearings.
By the way the total reveal about a small drawer should be about 1/32 to 1/16". This fit can be accomplished by hand planing the drawer to this perfect fit.
