Disassembling Glue Joints
Ken Adams
>So, we bought some used, inexpensive chairs; really we just wanted the table. Evidently, the set was a kit (or factory second?) originally, and when the chairs were assembled, the front (longer) and back (shorter) legs were reversed on some of the chairs. It's disquieting to sit in a chair and feel your rear trying to slide off the front of the chair and down under the table, instead of toward the chair back.
I'd like to disassemble the legs and put them on correctly, but how do I break the glue joints without destroying the wood pieces? Of course, I have no idea what glue was used, and as the legs are painted, protecting a finish isn't necessarily a problem.
I've tried wrapping wet rags around the joints, trying to soak them loose, but that hasn't helped at all after a few days.
Re: Disassembling Glue Joints
>Yikes, if well glued, I think that would be difficult without cutting some wood. Can you level the chair by trimming a bit off the bottom of the back legs, then applying something to the bottom if that makes the chair too low?
r payne
>Did you try heat? If that doesn't work then maybe some solvent.
ron
A Hammer... *LINK*
Bri in Mtl
>Seriously. I repair and restore chairs all the time and 90% of the time a deadblow hammer separates the parts.
Most manufactured chairs are assembled with dowels.
Just hold the chair in 1 hand an inch or 2 above your bench)covered with a soft surface) and give the joints a few wacks as close to the joint as possible.
You can see one here...
Hope this helps.
http://i47.photobucket.com/albums/f193/Bri68/Misci
Re: A Hammer...
>The few I have taken apart, I used a hammer just as described. I might put a piece of wood on top of the peace I am about to hit to avoid denting it.
My question is: Can you really take them apart and then reassemble them in a different order and change various angles without re-cutting the parts? I having trouble visualizing that.
Re: A Hammer...
Ken Adams
>I've tried beating on the joints, precisely (I think) the way you mentioned without budging them -- well, except for the ones that were already loose. You mentioned in works 90 percent of the time, so how do you handle the other ten percent? BTW, all the joints are obviously (round) M&T joints, not dowels (legs and stretchers are all spindles).
One person has suggested using solvent, but I've tried water, thinking it might be the right "solvent" for the assumed common PVA glue. Might try lacquer thinner later today, if it warms up enough to open the garage door.
Jim DeLaney, Austintown, Ohio
Re: A Hammer...
>Try white vinegar. It'll soften PVA glues - and hide glue, too, but water works just as well for the hide glue.
Jim D.
solvant
>That reminds me. A friend of mine uses a syringe to inject solvent into joints. You might drill a few tiny holes or hire some trained powderpost beetles. But what if the joints are assembled with wedges?
Too bad it's not hide glue - that softens nicely with heat.
BTW, I once rebuilt the entire works of a player piano and used an old clothes iron to get many things apart, remove old bellows cloth, etc. Restorers are cautioned to NEVER use modern glues so 40 years from now the next guy can take the thing apart again! The worst was the 66 little striker bellows, one for each note, each glued onto a wooden vacuum manifold box. Following the advice of the pros, I didn't use heat on these but took them off by splitting them with a putty knife. The small amount of splintered wood was used as a guide for perfect alignment during reassembly.
Re: A Hammer...
Ken Adams
>Worth a try. Thanks. I have some hypodermic syringes, so maybe I can get it in there moderately well.
Re: solvant
Ken Adams
>Well, if there are wedges, they aren't evident. Of course, I could imagine putting wedges in the tenons, then banging them home in the mortises. Yeh, that could be a real problem.
These are cheap chairs, so they aren't really worth massive efforts. But then, this has almost become a crusade! One way or another, at least one of these chairs is coming apart!
Re: solvant
>Good Evening Ken,
I would be inclined to level the chairs/correct the lengths of the legs with a saw and riser blocks as appropriate. Putty and repaint. If your joints work, don't "fix" them.
George
Re: solvant
Ken Adams
>spoil-sport!
Yeh, I know you're right, but that means giving up on a quest.
