Raised panels using MDF
John_in_Az
>Greetings - I'll be attempting my first raised panel doors soon. I will use poplar for the rails and stiles and since they will be painted anyway I thought I would use MDF for the panels. I can see some benefits (stability and cost), but wonder how hard MDF will be on my bits. Any other downside and advice. Thanks, John
Re: Raised panels using MDF
>Good Afternoon John,
I did about a dozen cabinet doors for my #2 son and his wife. They were painted poplar frame/MDF raised panels which were done on the router table. MDF works well, and I did not note any discernable dulling of the cutters. I took several passes to reach the desired depth and profile. They came out smooth and crisp.
George
John_in_Az
>Thank you George for the response. You affirmed what I had read and know about using MDF. I don't mind spending the money for the right product for a job, but why spend more than is needed. I like the idea of saving not only cost but time and effort to glue up the panels. What I didn't want was to be foolish in the cost saving aspect and trash the expensive bits ie; no saving, lol. Thanks again, John
George had it right
Howard In Toronto
>But I'd like to add one more observation.
Clean the bits often.
The glue in MDF tends to build up similarly to pitch.
Otherwise George's advice was spot on.
Howard
George ALWAYS has it right
>Guess it comes with experience!
Happy Woodworking!
All MDF is not the same
Keith Newton------WebKitFormBoundaryDZmgloT+ZiYFgX
>You may ask your supplier where ever you are what your options are. Some are rather softer than others, which may machine easier, but not cut / sand as smooth, but the harder ones would be harder on the bit. But surely getting a router bit sharpened would not cost too much? I sharpen my own, so I don't know what the normal charge is, but for two edges, it couldn't be much.
John Ballance
>I've made several raised panel doors for my daughter's house using MDF for the panel. The only advice I'd offer beyond what George already provided is to set up some dust collection at your router table, AND wear a good dust mask. Routing MDF creates a cloud of dust -- you'll be wearing the dust before you are done with the panels, but the panels will look very nice.
I've not noticed any bit dulling from these activities.
Good luck.
Scott Whiting - Glendale, AZ
>Because you do not have to allow for the expansion of the panel you can even make the panel without much slop and glue it in instead of floating. It then becomes part of the door structure. I've seen it done on entry doors too.
John_in_Az
>Thank you all for your input. I especially like the idea of gluing the panels for strength due to the low movement of MDF. Also, thanks for the heads-up about the dust hazard. I was just going to use the paper type mask, but I think I'll break out the better cartidge type filter I have for painting. Gratefully, John
