bad dust collection on a Griz jointer
les winter
>I have a Grizzly G0500. It's an 8" jointer. I've run 6" piping from my 2hp dustcollector blower. A wood plate receives the pipe and connects to the jointer dust chute. I removed the smaller factory connector. So I get a gentle stream of fluffy cuttings ejected from the cutter head, back towards the infeed table. After some use, I get a wad of shavings sitting up at the cutter head, in the chute. I have plenty of suction.
I looked up the chute and saw no grill or other obstructions, but the opening from the cutter head to the chute looks kind of small. Before I remove the outfeed table to investigate further, maybe one of you has a suggestion?
thanks
Les
Re: bad dust collection on a Griz jointer
Ed Mulligan, Cape Cod
>Sounds like a clog up near the cutter head.
les winter
>Thanks Ed. That happens periodically, and I clear it out, but even when clear, I get dust blowing back.
>Les,
I can't help you directly, but somebody posted a message within the last month about changing the cutter head on the jointer to a spiral or segmented one. There was a comment in it about removing a piece from the area to increase airflow. I don't know what jointer that was or if it applies, but maybe.....
Maybe you don't have enough air flow. To have "goes out" you have to have "goes into". If the chute is closed off too well, you won't have much air flow no matter what size the outlet and pipe are.
alternative operation
Bill Tindall, E.TN
>I realize this is not exactly the answer to your question.....I just stick the collection hose up the chute on my Delta jointer. This arrangement gets 95% of the chips and I can pull the collection hose out, lay it on floor and sweep floor dust/shavings to the hose for pickup.
It sounds like you don't have enough air flow/velocity through the cutter head. I presume chips fall out the chute ok without the port sealed?
les winter
>Thanks Barry.
My unit does not have the extra screen that was posted about some time ago. I checked visually and with the factory. They had no clue as to how to solve the problem. It is likely that they undersized the opening.
Re: alternative operation
les winter
>Hi Bill.
The lighter chips float out the cutter head towards the infeed table. there just isn't enough draw through the cutter head opening to capture them. Your idea about bringing the suction tube up to the head from below is interesting.
thanks.
>Sometimes you are just lucky. I just hooked a 4" "take off" over the outlet on my Ancient Delta jointer and it works fine. Way less than 1% escapes.
Sounds like you are having the same problem I have with my TS. The blade carries a certain amount of dust back around and through it out the top. Would it be possible to lower the knives in your jointer and then lower the outfeed table to match? Would that increase the gap, allowing for more airflow? I'm guessing not much and some or all of the gap would be covered by the board itself.
Can you lower the chute a bit to increase the space at the top to let more air through? Hate to suggest you mangle your jointer as an experiment. but you could cut holes in the chute or cut away the top lip, but I fear that would have as much chance of making it worse as improving it.
les winter
>This is some swell design. they brought the chute up even with the top of the lower cabinet and dropped the upper casting on top. the upper casting sits on small legs, so it is open all around and the adjusting shafts are open at each end. They should have brought the chute up to meet the casting's undersides. I use throw-away knives which cannot be lowered.
Thanks for your thoughts.
Jay St. Peter - Southern, MD
>I have a G1018, the predecessor to yours. My impression was that yours is the same basic design but with table extensions and different fence.
Even if I don't run DC, the majority of the chips go down the chute. I've never had a clog at the head. I've used both the stock and a Byrd cutterhead. Maybe it's something to do with your disposable blade setup? Did it happen with the original blades?
What about raising the guard?
Steve Silca
>You guys have me thinking. I have an 8" Grizzly that I got about two years ago. I ezperience the same dust problem. I also have 6" ductwork right up the port at the end of the dust chute.
I have a second problem as well. The guard drags on the tables and doesn't always retract back to the fence every time. To be honest, I've just lived with it.
Perhaps you and I can kill two birds with one stone. What about raising the guard? This might increase airflow. Plus, I look at my old jointer and the guard is like a 1/2" above the cast iron. What do you think?
Re: What about raising the guard?
les winter
>Hello Steve.
The guard should be tight to the table or as tight as possible. In my case, the dust blows out when the guard is open and when it is closed. There is a relief cut in the infeed side of the guard that allows 1/2" or so of air flow. I think there are two ledges at the top of the chute which accumulate chips which then blow back.
les winter
>If the guard doesn't retract, loosen the cross bolt, close the guard and retighten the bolt. It should swing closed freely and snap closed by the pressure from the spring. If it doesn't, raise the guard a hair, so it clears the table. If that doesn't do it, stop using the machine until you can figure out what's what.
Bart Leetch
>My ^" has a small gape centered on both sides of the bottom of the Jointer which lets in plenty of air flow. See picture.
