Gotta getta bandsaw: need tactical advice
Roy Anderson
>I think I've decided on the new Rikon 10-350 14" bandsaw. The things that are worrying me are the tactical issues of getting it off the truck and down to my basement.
Does anyone know what kind of container it comes in and how best to unload it? I read that the driver will bring it to the rear of the truck but won't help in unloading. I have a hand truck, so once I get it to the ground, moving it into my Garage won't be a problem.
I also need to take it down to the basement in pieces and assemble it in place. I don't know what kind of sub assemblies it comes in and how hard this will be.
Any thoughts?
Re: Gotta getta bandsaw: need tactical advice
David Yoho
>Although they say the driver is only responsible for getting the load to the rear of the truck, my experience has always been that they will help you get it off the truck and into your garage. You're on your own as far as the basement part goes.
If the carrier calls before delivery, ask if the truck will have a tail lift. This sure makes these things easier.
My Delta 14" arrived in numerous boxes and was not hard to move. However, my MiniMax 16 came attached to a pallet and was a real bear to move. It was almost all assembled. Even without the table attached, it was still very heavy.
A good hand truck and several strong backs should be able to safely get that saw downstairs.
Paul Waddle
>I would wait until the weather was good. I would also enlist help! I would hesitate to dissassemble too much-maybe the top part,mtr,table,but would leave the rest intact. I'm not sure how it will come,bet it won't be too substantially packed. It probably came over in a closed container that was packed carefully but don't think that carried over to the individual pcs-hope I'm wrong.
I think you are getting a very fine saw-I believe bandsaws put Rikon on the map. pw
In pieces?
Charles R. Smith
>Roy, I don't know about your Rikon, but I managed a General 15 inch bandsaw down basement stairs by myself. I took as much off as I could, starting with the motor and the cast iron table, and soon had it down to the skeleton of the steel frame. The bandsaw's stripped-down size fit nicely on a dolly, so it could be moved by one person (me). When I reassembled it, I got to do a fine adjustment on everything, and it worked like a charm.
Charles (whose back didn't even complain afterwards)
Re: I am assuming it was similar to my 18".....
>Rikon bandsaw. I had it delivered to the loading dock at work and then loaded it a borrowed trailer and then took it home. It was a single crate. The bandsaw was not assembled.
I removed the outer packing crate and moved the table and other small parts around the house down to the back entrance to my basement - that was about ~100 lbs or so. I then strapped the bandsaw (~250 lbs or more) to a heavy duty handtruck and moved it. My handtruck is heavy duty - if you don't have one, you might think about renting an appliance handtruck from one of the rental places. The 14" is lighter, so you may not need an appliance handtruck.
Rikon 10-325?
Curt Harms
>Are You talking about the 14" Rikon with the 12" resaw? If so, I did this very thing by myself. It comes in one cardboard carton. In the cardboard carton is a form fitting styrofoam packing. The table comes detached-take it down stairs. The fence and other miscellaneous fittings are separate. I just slid box, saw and all to the steps and down, it's not all that heavy. I did hook a come along to an overhead beam to lift the saw onto the base. It wasn't hard at all. If You have help it'd be quicker and easier but I was able to do it myself.
HTH
Curt
Re: Rikon 10-325?
Roy Anderson
>It is the 10-325. I originally posted a wrong (non-existant) model number.
Re: In pieces?
Roy Anderson
>The deal with the basement is that I have a finished basement, except the little room where my work shop is and the stairway is enclosed, drywalled, my wife just repainted it and it has a landing and a 90� bend in it. So it's gonna be hard to slide a big tall bandsaw down that thing in one piece and scratch zero drywall.
The alternative is to truck it around to the rear of the house and go through the walk out basement door, which involves steep ground, but might be the safest bet all things considered.
It might work to rent some sort of dolly or wagon with big tires to cart it around the house on. I just need some sort of visualization of what kind of crate it comes in.
Check your email
Curt Harms
>Hi Roy
Check your Yahoo email account. I sent a pic.
Curt
Re: Check your email
Bart Leetch
>You shouldn't have a problem I hauled my 14" Grizzly home in the back seat of my 1990 Chevy Lumina & slid it out & set it on end & then slipped the hand truck under it & wheeled it to the shop. I don't see the Delta being much different in size or weight.
Bart Leetch
>Sorry I meant to say Rikon 10-350 14" bandsaw as being much different.
