Camera Battery Revisited, problem solved
>I have posted several times about the batteries in my Kodak Easy share camera going bad. It has a little cradle with two AA batteries mounted in it. I know it will accept two single AA batteries, butt he ounces in the cradle are rechargeable and charge in the dock when you connect it to the computer. Being cheap, I bought two rechargeable AA batteries and stuck them in the camera. They did not charge.
Today, I went back to best buy and talked to there "camera team". Their consensus was the dock had gone bad. I was wondering how it could happen that the battery wore out and would charge, but not hold the charge and then the dock died right when I decided to change the batteries. I bought a new set of batteries mounted in the little cradle, with the promise I can return them if they don't' fix the problem.
As I was riding home, it occurred to me that there is more to the little cradle than I thought. There is nothing electronic about it, no chip for the camera or dock to read, but it turns out there it depresses a tiny (really tiny) switch inside the battery compartment. This is what tells the dock that these are rechargeable batteries and not just regular AA's. Problem solved. The new batteries in the cradle are charging as they should. I guess $17 spread over five years is not bad.
Thanks for the help.
Re: Camera Battery Revisited, problem solved
I've got the same problem...
Martin from Granbury
>I am not sure I understood your solution.
Did you get new batteries and a new dock? or just one or the other?
When I dock my camera, the battery lights don't light up at all.
The download light does, so I know the dock "senses" the camera, but the batteries don't seem to recharge. Perhaps I need new batteries.
On the other hand, the camera is old and probably should be replaced entirely.
Here's another hijack...
What software do you use for your photos? Easyshare doesn't seem to be easy, but rather confusing.
I am wondering if I should try Photoshop or the Nikon version that came with the newer camera.
OK, I've rambled and asked far too many questions.
Anyone's thought are always appreciated.
Thanks,
Martin
Re: I've got the same problem...
>What I did was go to Best Buy and get a KAA2HR and paid about $17-18 bucks for it. It worked exactly like the one that came with the dock.
What I have figured out is that its the little cradle that the two batteries are glued into that has a little haunch or tenon on it that flips a switch inside the Battery compartment that tells the charger to charge the batteries. Without the cradle, you are "safe" to use regular "non rechargeable" batteries. Now that I have figured it out and seen the switch it makes perfect sense. The camera or dock has to "know" whether to charge the batteries or not. You would not want it to try to charge one-time use batteries.
You can buy the KAA2HR at www.bateries.com for about 10 or 11 dollars, Including shipping. I should have ordered one and saved the money, but I tried to get this over with today. Still not used to shopping on-line.
You can buy rechargeable batteries locally and I think that if you were very careful you could pry the old batteries out of the cradle and tape or glue in the new ones, but the spacing and alignment would have to be really accurate. I tried it with mine, but I decided to give up and take the easy way out.
I use the Kodak Easy Share software. I recently downloaded the newest version. Its a little better than the old version, but not much. Whoever named it "Easy Share" anything seriously lied.
There are others here that can give better advice on which software to use. I have not upgraded or changed. Feet of clay, I just keep fumbling along with what I have.
Dan Donaldson
>Can't help with the batteries, but maybe the software angle. The first question is what do you want to do with it? Just resize, maybe a bit of cropping, etc? If just that, then something like Photoshop is a very expensive overkill. In these cases, take a look a irfanview or picasa (both free). They give a lot of capability without being too complicated. If you are into extensive photo manipulation, then you would need something like Photoshop (expensive) or Gimp (free). These programs have a tremendous amount of capability, but also a steep learning curve.
