How do you store your sheet good?
Lee Beeden
>I've decided its time to do something about the sheet goods that get lent up against my shelfing unit at the end of the shop.
Its always a pain to get anything of the unit, and I'm sure theres a better way to keep the plywood flat.
I'm curios as to what your solutions are, if you have any pictures that would be great!!!!
Thanking you all in advance.
Lee
Re: How do you store your sheet good?
Steve in Denver
>Here's one idea, not sure if you have room or not.
http://www.woodstore.net/trstforlusca.html
Right behind all the sheet good scraps
everything looks good... except the wheels
Scott in Montana
>Should you build this, upgrade to the best wheels you can get. It's not hard to get 750 pounds in a cart and when you do, Home Depot casters don't like to turn... even though they're rated at 500 pounds. They'll hold it... they just won't turn. Don't ask me how I know all this. :O)
Scott
It would be good if
Keith Newton------WebKitFormBoundaryDZmgloT+ZiYFgX
>You posted how big your shop is, and how much material you need to store.
Re: It would be good if
Bill Sams
>Here's a pic of my sheet goods. In Andy Rae's "Workshop Idea Book" there are also many examples of storing sheet goods.
My system consists of 2x4 frame panels, sheathed only on the two ends and top and bottom. Each section allows for the thickness of about 6 pcs of 3/4" plywood to be stored and still allowing room to retrieve. Since I use alot of 5x5 sheets, I built this to accomodate both 5x5 and 4x8 sizes. Small spacer blocks to fit each section helps keep the sheets from slumping when there are only one or two sheets in each cell.
The entire unit is 10' tall, so above the 8' sections there are 2' sections available for scraps.
Make sure you make your opening 1" taller than your sheets goods, otherwise you will fight to get them in or out, ie 97" vs 96"
Hope that helps.
Mike Fitterling
>I built this shed for a about $1500 (8'x16') and store all my sheet goods and main stock of lumber inside. It is right beside the big door to my shop. It makes a huge difference to get the wood right out of the shop when I am not working with it.
