Veneer Tape Dispenser??
Joe Burke
>Has anyone seen plans for a shop made veneer tape dispenser? Store bought types run around $150 and that seems way, way high for what it is. I thought I'd seen something ... somewhere .... sometime
Re: Veneer Tape Dispenser??
Earl Kelly
>Joe,
Yes,the tape dispensers are expensive, but after 30 days of using it you'll wonder how you ever got along without it. They take 2 rolls of tape and make it so easy to get just the right amount of moisture on the tape.
Earl
Brian in Sandusky, OH
>I really think that the best way to dispense veneer tape is just to tear is off by hand, and run it over a wet sponge on a plate.
I have bought three different veneer tape dispensers over the years, and I still use the sponge.
Joe Burke
>That's interesting. I'd hate to pay $150 bucks for something and find it was sub par.
Re: Veneer Tape Dispenser?? *LINK*
pecker
>I would think you could use a regular tape dispenser, for around $20, with a sponge positioned strategically in front of the dispenser. Maybe have the sponge in a small tray of water.
http://www.uline.com/ProductDetail.asp?model=H-462
Earl Kelly
>Joe,
I got my tape dispenser from Vacuum Pressing Systems. It uses rollers, no sponge, and a water reservoir and holds 2 rolls of tape. If you're doing small projects, it probably would not be beneficial. I purchased mine when I had a project with 2,000' of veneer panels to do.
Earl
Carol - now in NC Nebraska
>Years ago, packing tape had to be moistened to be used. Somewhere I have a ceramic dispenser. There is a small tub for water and a ceramic roller that sat freely in the water. You simply thread the tape over a rounded edge into the water, under the roller, and up and through a serrated edge for cutting. The roller is heavy enough to stay in the water, even when pulling tape through.
Probably could make one easily enough, now that you know how things used to be. :)
