THE WOODRAT IS BACK!
Used 8" Woodtek jointer *LINK*
Dan Mitchell
>Anyone familiar with this jointer? I found a used one for $675. Someone on another former said "The WoodTek is a Geetech clone. Same basic machine as the Jet, Bridgewood, Grizzly (until last year), etc." Don't know who "Geetech" is. Any thoughts on the machine & price appreciated.
TIA
Dan
8" Woodtek jointer
Re: Used 8" Woodtek jointer *LINK*
Kevin Rabenaldt
>I have not used one, but I would test it out if the person will allow it. I do not know exactly what kind of cutterhead it has, but if it is the spiral kind, then the price may be a good one for a jointer in good shape.
A test cut will also give you an idea of the edge finish with the type of cutterhead and then you can decide if that is acceptable to you.
I believe in buying used equipment if the price is right.
Kevin
Howard Norman
>I think most of the jointers now are made in China so the Woodtek is probable very similar. I would definably try to give it a test run. From a quick look at the web page posted I would assume that it would be similar to the Grizzly G0656 that sells for $695 plus freight. I have the Grizzly G0490 with standard cutters that sells for $795 plus freight.
If it cuts well and seems to be in good shape it may be a good buy.
Howard
Larry Clinton At Frankfort (Central)., Indiana
>I believe the Woodtek is nearly identical to the Grizzly with the exception the Griz has a 2 horse motor. Link to the Grizzly is http://www.grizzly.com/products/8-Jointer-w-2-HP-Motor/G0586
Unless the joiner you are looking at has a spiral cutting head (small carbide inserts fastened to the cutter head). If it were me, I would opt for the new Grizzly machine for $839 (including shipping) rather than buy a used machine. The warranty would be worth the $164 - you would also know the machine hasn't been abused, the blades would be new - (sharpening blades would likely cost $30 ~ $40). If it is a spiral head then I would buy the used machine. If you haven't, you may want to look at all the Grizzly machines before buying, I feel confident the Grizzly is just as good if not better than the Woodtek. One advantage of buying Grizzly is that they do carry parts for all their machines. This may or may not become an issue in a few years. I have owned a Grizzly 6" joiner with straight blades, It served me very well. I have replaced it with the Grizzly 8" with Spiral carbide cutter head. The cut quality on curly/knarly woods using the spiral head is amazing. I have the Byrd spiral head on my 20" joiner & believe the Grizzly head to be almost, if not as good, as the Byrd.
Re: Not sure that's a good buy
Dave Mount
>Gee-tech is a Chinese company/factory that makes machines to spec for a number of different importers. I have an 8" Sunhill that a bought several years ago that is the same basic machine as you linked to. Sunhill said straight out that it is a Gee-tech and there is actually even a label on it that says so. Sunhill just adds their sticker to it. There are some minor variations -- for example when I bought my Sunhill it came with a four knife cutterhead instead of three, and had bolt on table extensions to bring the tables to 72" overall. In fact, I think Delta's low end 8" jointer is also made in that factory but I don't know that as a fact. Realize that this is not the same as saying the Wood-tek and Delta are exactly the same machine. Different companies may specify different bearings, motors, and other components for machines made for them. However, the castings are all coming from the same place and are being assembled in the same factory.
I think the same machine new can be had for considerably less than the $999 that the Wood-Tek machine is from any of several vendors. More significantly, the Grizzly 8" machine with parallelogram adjustment is something like $750 plus shipping with straight knives as I think someone else mentioned. A friend has that machine and I am very impressed with the value it represents.
Unless the used machine you found has significant add-ons (e.g., spiral cutterhead) that justify the price, I'd pass and buy new.
Best,
Dave
Jesse Cloud
>Being close to one of the Woodworker's Supply warehouse stores, we see a lot of Woodtek out here, both in hobby shops and in pro shops. The people I know who have them have never complained. Apparently Woodworker's does stock spare parts.
As to the price, if you like the machine, you might offer a lower price and see what happens. Woodtek doesn't have the same resale value as the big brands do.
Dan Mitchell
>Thanks for the informative replies. The consensus seems to be "skip it", at least at this price, so I think I will. I agree about the brand not having the resale of better known names. I've heard the Griz is good. I've had my eye on the PM 54A (matches my PM2000 ;-) which is on sale for $669 w/rebate at Rockler. Not sure about the local store's delivery $$$ It's 6", not 8". How much difference is that 2" in the real world?
Dan
Deal or no Deal, NOT a deal *LINK*
Ken Garlock, Collin County Texas
>I have a Sunhill 8" 2 hp jointer that looks like the Woodtek. I paid a little under $800 new about 3 years ago. (Mine says Geeteck on it.)
Sunhill now had the same jointer ON SALE for $595 plus $149 shipping. The Sunhill people are easy to deal with.
IMO, you are not getting a deal for a used one when you can have the same machine, or a good duplicate, with a 2 hp motor, for about the same money.
Happy saw dust,
Ken
Sunhill jointer
Re: Deal or no Deal, NOT a deal
Dan Mitchell
>Agreed Ken, thanks.
Dan
Gary Evans Tallassee, TN
>Hi Dan,
If the money is in the budget, I'd go with the 8". A 6" jointer will do everything an 8" will do except straighten the face on a 6 1/2" wide board. 8^]
Seriously, there have been numerous times over the years that I wished I had the wider cutting capacity.
Gary
Big difference
Most people start off buying a 6" jointer. Many of those people upgrade to an 8" jointer. Some of those people then upgrade to a 12".
So on the used market there are tons of 6" jointers and a few 8" jointers and almost no 12" jointers for sale.
That affects value and prices.
Happy Woodworking!
