Paint for Garage Workshop
Ed O'Neill
>I'm undecided about the best paint to use on my garage/workshop floor. I've looked at the paint systems sold at the big box stores and cant decide. I'd like to be sure after putting in the effort that my tools being moved won't destroy the finish. Any suggestions ? Thanks for your help. Ed
Re: Paint for Garage Workshop
Try two-part epoxy
Charles R. Smith
>I used the two-part epoxy paint from the orange borg on my garage floor. It has been impervious to all sorts of abuse, including sliding woodworking machines (lathe, bandsaw) over its surface. It's kind of messy to apply, but the results are worth the bother.
Behr water based one part epoxy
Don Orr
>I used a 2 part water borne epoxy paint by Muralo. I love it. Went on easy, very little odor, and tintable. Got it at my local paint store-NOT a borg. It is guaranteed to not lift off under hot car tires so it it pretty tough. Surface perp is important. Mine went on fresh concrete after a couple monthd of curing and a thorough cleaning. So far, so good !
Larry Clinton At Frankfort (Central)., Indiana
>I used the Garage floor Epoxy kits by Rustoleum. I have the grey, with the speckled flakes (you sprinkle onto the floor after applying the epoxy). My floor was over a year old when I applied it and had already had oil, grease, stain, shellac etc spilled on the surface. (We had worked on vehicles in the shop so PS, Brake and transmission fluid had also been on the floor. In addition I had used a sealer/cure on the surface when it was poured. The container says the epoxy may not adhere to a "sealer". My shop is 30' X 30' so used about 3 kits. We did clean and rinse the floor very thoroughly using citrus cleaner, then the cleaner in the kit. We finished one half, let it dry for a couple days then cleaned and finished the other (Didn't want the big tools out in the open overnight). The performance has been excellent. I have a 20" stationary planer, Unisaw with extension tables & mobile base, 8" Grizzly joiner, MM-16 bandsaw, and large router table, 2 large tool cabinets / chests - everything is on mobile bases (and does get relocated often, dependent on the project we are building). We have also moved the equipment aside and rebuilt the motor on my sons Van in the shop, with all the attendant mess of fluids (they cleaned up easily when the job was done). It has been about 3 years now, and there is NO missing epoxy. There are a few scratches where I have caught something (gravel or nail) on a caster of the planer. Even then the coating didn't scratch through.I think the planer weighs 700+ lbs so didn't expect the coating to hold up near as well as it has. When / if it ever needs re-coating, I will use the same material again. It is not slick, has a semigloss surface - think the "sprinkles" keep anyone from slipping. I really like the appearance. I have cleaned areas with Acetone, Naptha, Alcohol etc. with no effect. I do have some glue spots here and there I should remove - someday maybe :~).
John in Calgary
>I put down the Rustoleum two part garage floor paint in September and so far it has held up quite well. Our floor was ~5 years old and had a few oil stains. I gave it a very thorough cleaning before hand (if you have oil stains, search on here for Forrest's cleaning process). The coating can be quite slippery if it gets wet so be careful. I mixed in the Rustoleum traction material (it looks like a clear sand material that comes in a small package), but it still catches me by surprise sometimes.
One side affect - with winter comes snow, salt and dirt. In the past, as the snow would fall off the underbody and wheelwells, it would slowly melt and the water would disappear into the concrete leaving a dusty debris (in fact, this is usually the dustiest part of clean-up in my garage after woodworking). Now, the water doesn't absorb into the concrete anymore leaving muddy debris piles, pooling water and a frozen layer near the garage door where the water is trying to run out of the garage. It is much messier during the winter months and I find that I am constantly trying to squeegee the debris out before it gets too out of hand. That said, the coating has held up to scraping with a scraper to remove the ice.
John
Dean Campa - Texas
>Larry,
You have done exactly what I am planning on doing. (older floor needing cleaning,same product brandand color of flooring as well as two stages - i am not storing my shop outside) But I have a question for you. Was there any problem with an uneven floor or matching up the coating when you did it in two stages? If so do you have any hints. Also, what kind of citrus cleaner did you use my attempts have not been to successful. Your comments would be appreciated. Thanks from Texas
