how flat is flat enough?
RobRing
>I have a stanley #7 plane whose sole I need to flatten. The lengh of the plane far exceeds my usual flattening surface, so I thought I'd use a spare cash iron table saw wing I have. Of course, it's not perfectly flat either. The wing is 27" X 10". Across the width from top to bottom it's as flat as it needs to be (within 0.001"). Along the length it ranges from a .002" dish in the center of the wing to a .004" dish near each edge. diagonally it's dished .003" along one diagonal and .004" along the other. I try to avoid being so obsessive about applying machining-type tolerances to my woodworking, but in this case it's technically metal working. Is this flat enough to use as a flattening surface for the plane? I can have the wing precision surface ground at a local shop for $40, but I'm not sure if it's worth the trouble.
As a corolary, what is generally regarded as acceptable tolerances for tablesaw surface flatness? Is this wing even suitable for it's original purpose?
Thanks,
Rob
Re: how flat is flat enough?
Larry Marker
>If your local machine shop will precision grind your table for $40, I'd see how much they would charge to grind your plane sole. Might save you a lot of time and effort.
Larry
I think a plane sole shouldn't be exactly flat.
Forrest Addy
First my theory: The plane is a dumb gadget. Running a plane back and forth over the work won't make it flat. The woodworker has to follow some definite process if he is to acheive flatness, parallelism, and thickness of a workpiece in an economical and orderly manner. In normal use of a plane, the woodworker, brings the high areas of the work to a plane using a try square, winding stick, etc for feed back along the way to lotate high spots as they emerge and straighted out warp, wind, and cup. For this we use a jack or a smooth plane for the bulk of the work graduating to a #7 at the final hurrah.
I postulate a plane used for flattening should be configured somewhat like the tables of a jointer. That is the infeed surface (toe) exposes the cutting edge and the outfeed (heel or run) only exposes enough of the cutting edge to prevent sniping. In a hand plane with a fixed toe this is a compromise.
Also a hand plane should have a little "rocking chair" to its net shape otherwise the plane becomes almost unmanageable. It can't be disengaged from the chip. Once committed to a chip the woodworker has to follow it out to the edge of the board. The "rocking chair" allows the woodworker to dip in and out of the work at will without thinking about it. Thus he can focus on the high material working it down to geometrical perfection. These deviations from flat are measured in thousandths of an inch and the deviations are larger in smaller planes than for larger. Then there is crosswise deviation and other refinements. The shape of a plane sole can be a complex topic and discussion of it may lead to controversy at the "how many angels can dance on the head of a pin" level.
Getting back to the #7 and the OP's question. I suggest he make the plane sole practically flat with a 0.0015" toe exposure and keep three irons handy for it; each with differing end chords from absolutely straight (with 1/4" end relief) to 1/32" chord for semi-finishing. Use the straight iron when the plane is set very fine for the last cuts and the chips thinner than paper. Use the irons with more pronounced chord for sneaking up.
I don't agree with the treatment of troughing out perfectly good lumber with a hand plane to simulate "hand workmanship". Stuff like that got you fired back in the day when all tool marks were routinely erased from finished surfaces at great care and expense. But then I'm a notorious party pooper.
So my solution to the OP's problem is the sole of a #7 should be configured as two parallel planes offset by 0.0015" to 0.0025" with the transition at the mouth. The toe plane exposes the cutting edge to take a chip the thickness of the offset; the heel plane leaves enough edge esposed to ensure cutting.
Too fancy?
wrong forum, my thoughts
Bill Tindall, E.TN
>This question needs to be posted on the hand tools side where it may initiate a lively discussion.
I have seen club members, myself included, ruin several planes trying to flatten the soles by hand. These failures were followed by trips to the machine shop for surface grinding. For what ever this experience is worth.....
1. I don't think most people can flatten a plane sole by rubbing it on an abrasive affixed to a "flat" surface like a jointer bed. You will in all likelihood wind up with a convex sole.
2. When I am buying an old plane I check the sole. If it is not flat enough I don't buy it as the expense to get it flat, plus adding a better cutter leaves one better off having bought a Lie Neilsen or Lee Valley to begin with. The steel in old Stanley cutters(irons) is pretty soft by modern standards and they are so skinny that they are difficult to sharpen free handed.
3. If you need a sole flattened hire someone to surface grind it.
7 A No7 is of not much use to someone using a hand plane as a supplement to power tools. There are good reasons that the most common planes one will find are 4's and 5's.
Bart Goldberg
Bart Goldberg
>While I'm not expert, my suggestion is to purchase a several foot long piece of float glass - It should be flat within the range of tolerance you need.
Good luck
Bart
Acually float glass isn't mst flatter
Forrest Addy
>Acually float glass isn't mst flatter that the substrate its sitting on. If you want flatness, purchasee a cheap granite flat from one of the manchine tool supply catalog houses. Here's an example:
http://www.use-enco.com/CGI/INSRIT?PMAKA=640-0120&PMPXNO=949402&PARTPG=INLMK3
$25 and it's really flat. With a little prussian blue and a scraper you can flatten your plane soles to 0.0002" if you feel it necessary. Shipping for a surface plate is a killer. Look for a local source if you can find one.
My Opinion and My #6 Stanley
>Hello Rob,
If you plane a couple of pieces of wood, and they fit together or fit well where intended, its flat enough. Of course, the wood may swell, cup, twist or bend. I don't sweat the small stuff anymore.
I remember reluctantly taking a battered Stanley #6 as partial payment one time. The sole was dinged and dimpled because the guy's kids used a ball peen hammer on it. My #3 son was attending Williamson Free School of the Mechanical Trades, and his room mate was in Machine Shop. I asked Ken to see if the machine shop and his room mate could lap the sole of the #6. They agreed for him to take it on as a project. He had to repair the lapping wheel first. Then he proceded to lap the plane sole, and that came back so polished I could see my reflection in it. I made a new knob and tote, sharpened the iron and wound up in Heaven. I never did check on how FLAT it was, though. My guess is that it was flat enough.
George
RobRing
>Thanks for all of the feedback - certainly a divergence of opinion. I'm going to move the question to the hand-tool forum, where I'm sure there wil be much more universal agreement. ;-)
I actually acquired the #7 sight-unseen. I wouldn't have paid for it if I had a chance to check the flatness - buyer beware. But now I have it and I'm one of those weird folks that likes to do thinks the hard way sometimes just for the satisfaction of doing it. Sometimes the joy is in the making. I've hand lapped a range of different planes to "flat enough" on a 9X13 granite plate and I'm always pleased with the results. Of course, the 7 has a lot more mass to fight against and this one in particular has a lot of flattening necessary. That's ok, my wife says I should work out more.
Thanks again.
Rob
How is cast iron scraped
Bill Tindall, E.TN
>Not knowing what I was doing I tried it and accomplished making a bit of dust.
PS Will you do a discussion of what various file names mean- double cut, American pattern, etc?
Bill. I'm not leaving you on the hook
Forrest Addy
>Bill. I'm not leaving you on the hook but I can't find the stuff I know was in the WC archives - someplace. There were considerable resources written by me, Steven Thomas, and others on filing and scraping as applied to cast iron hand planes soles. Maybe you could dig into the corners and recesses of WC and find something. I'd hate to have to write all that stuff over again.
Would you be interested in a scraping class? There seems to be interest building in Kansas City, Kansas. I refer to precision hand scraping to rebuild machine tools but the lessons apply to hand planes as well. Kansas City isn't real close to Tennessee but maybe in range.
I did find this
Forrest Addy
>Someone re-posted this from a past Badger Poind thread:
Forrest Addy's Take on Scraping
I'm glad to help. I suggested you post your questions to me in connection with a Clifton jack he was having trouble with and desired to flatten on Neanderthal Haven. You'd get the benefit of several experts plus a referral or two to the archives. There may be others looking for a how to scrape tutorial. I don't know the information turnover in NH but may this is an acceptable time for the subject.
Have you tried the plane, as in cleaned it up, sharpened the iron, waxed the sole and went after a twisty old board to flatten it? I don't know if you followed discussion farther down where I asserted that absolutely flat soled planes may not be the best tool for straightening boards. If it aint broke, don't fix it. You don't say if the sole is convex or concave over the length.
As for your tools here's a few remarks and comments on abrasive lapping as I view the process:
First, I confess to a morbid fear of glass in the workshop thanks to an auto accident. I won't have it as a tool in my shop for fear of breakage.
Most abrasive sheet lapping I've read about recommended a thick piece of plate glass - 1/2" thick is mentioned and "Wet-or-Dry" abrasive sheets not sanding belts. I've abrasive lapped plane soles myself but I use a cheap import granite flat from Enco as a platen, not glass.
I'd think your 1/4" thick glass would be pretty thin unless backed up by something flat like a table saw top. Glass is among the stiffest of our common materials but if thin it will still flex under load.
What grit are those abrasive belts? It'd start with no coarser that 80 grit. Are you going to bond it to the glass somehow to hold it flat? My concern is their relatively heavy fabric backing may rise up where unloaded to uncontrollably round corners. Conventional wisdom has the abrasive lapping process start with 180 or 220 grit abrasive sheets, and as the sole comes flat progress to finer abrasive.
Moving on to scraping.
Scraping is back breaking work. Unless you're young and fit and have a strong back you'll wish you were long before the scraping job is done.
The tools are simple and not that expensive. A $40 import granite flat (glass will not work - no texture), a couple of good second cut 12" square files with handles, a 2" - 3" long stencil or rubber ink roller from the art supply store, some old mill files ground to make scrapers, a bench grinder and an oil stone - plus a $4 tube of Prussian blue from the auto parts store. Oh yes, plenty of rags and hand cleaner. Also have on hand a shop vac with an old hose to pick up the scrapings and filings. And a can of hand cleaner.
First an important message. Prussian blue is a pigmented transfer medium. Be aware of your fingers when they are smudged with Prussian blue. You will have visible evidence of their progress between initial smudge and realization all over your shop. One smudge on your finger will transfer to the light switch, your shirt, your nose, your ear, the back of SWMBO's silk blouse when you smooch her "thank you" you for the coffee she fetched. Wherever there's a smudge is another transfer-to-finger waiting to happen. Prussion blue is communicable like the plague.
The granite flat (Many call them "granite surface plates" but to me a surface plate is cast iron and made to be portable. Somehow I can't get past my training: to me the granite gizmo that does the same thing as a cast iron surface plate is called a flat.) is available from Enco Mfg. 1-800-873-3626 or www.use-enco-.com. Their Model 640-120 for $39.96 12" x 18" flat may seem largish for a small shop but it's long enough diagonally to rework jointers with a minimum of overhang. A little overhang properly addressed poses no problem to final flatness.
You can get import granite flats for about the same price from most any catalog site serving machine shops. MSC, Travers, tec.
10" and up mill smooth flat files are the best starting point for home made scrapers. Any junky old thrift store file will work. Dust off the worst of the teeth with an angle sander and provide it with a handle.
Advance to the bench grinder. Holding the file at a 5 degree (roughly) angle to plane of rotation and using the side of the wheel, remove the teeth for 5/8" back from the tip. Then grind an arc on the end of the scraper using the wheel periphery. The arc should be about the same as the rim of a 3 lb coffee can. Stone both surfaces smooth but leave a sharp intersection. You've made what amounts to a chisel with a 95 degree edge.
There are superb storebought carbide scrapers on the market. I suggest the hand scraper sold by the Dapra corporation (http://www.dapra.com/html/biax.htm) but they are expensive ($90 to $150 depending). The home shop typically doesn't have diamond sharpening equipment. If you know a rock hound having lapidary equipment consider him a scraper sharpening resource. A keen carbide scraper outlasts carbon steel about 100 to 1 (I'd almost swear). If you can fit a carbide scraper in your budget and you have several projects to justify it, I'd reccomend the purchase.
Here's a flat statement: you cannot satisfactorily sharpen a carbide scraper on a green silicon carbide wheel. The edge micro-chips and the effects of the crumbled edge will show in the ugly appearance of the scraped surface and the sweat dripping from your brows and elbows. Only diamond abrasives work well on carbide.
Carbide stones remarkably easy on those flat diamond plated stones such as those made by DMT and Norton...
Carbon steel doesn't last long scraping. It will dull rapidly. Resign yourself to touching up the edge every few minutes.
Sole prep. Remove all rust from the sole (rust EATS!!! scrapers and files). Install the frog and tighten the screws.
The first step is filing. A second cut file removes metal much faster than scraping. Note the square file has a "belly" a convex portion. It will allow you to concentrate filing the high metal. Clamp the plane casting in a vise so it's mid-forearm high. Glide the file over the sole to see of there's anything sticking up. Scraping and filing is a task involving all the senses and lends itself to a Zen-like contemplation.
Apply six or eight 1/8" dabs of blue on the plate and spread them with the ink roller. Vacuum clean the sole casting and apply it to the flat. Never apply the flat to the sole clamped in the vise. The force of the vise jaws will spring it a trifle and you'll end up with a plane sole that's concave across the bottom. be careful you don't rock the work on the flat. You can scrape a perfect convex if your're careless when taking a "print".
There will be a few smudges of blue on the bottom. File out only the blue using the belly of the file. Refresh the blue with the roller. Take another print and file out the blue. File crossways to the first strokes. Proceed for up to several evenings until the sole shows a scatter of blue patches all over. Sooner or later you'll discover just how hard to file (don't rub the file on the work, make it cut) and just where.
As work progresses the transferred blue will fade. You'll need to roll out more dots of blue to the flat every now and then. How much is a judgment call. Gain the skill.
Cleanliness is important. a single filing chip or piece of lint will screw up a blue reading (called a "print". Get a foot switch for the shop vac. If you see flecks of metal stuck in the blue, wipe the flat clean and re-blue. Use that shop vac and keep the scraping area clean. I've seen scraping benches that looked like a coal cellar. The work produced there was poor and expensive. Clean is cheap.
Proceed with the scraper. Practice a little on scrap cast iron until you can predictably make little flaky chips and nice parallel scrape marks. You'll soon learn to tip the scraper this way and that to catch blue spots not quite in line and to relax the downward force so the scraper's edge glides across low metal without cutting. You'll also learn to consciously relax your shoulders and neck. The little short controlled movements required for scraping force you to oppose one muscle groups with other muscle groups. Persist and your whole shoulder girdle and lower back will become one big knot you'll have to stew loose in the hot tub.
It does no good to rub the blue off with the scraper. You have to apply enough force and effort to remove metal. The skill is acquired through skill and practice. Make chips and study them through a 10X loupe. When old timers hand scraped for stock removal the powdery cast iron fountained 3" above the scraper but we're looking for control just now.
After scraping, lightly stone the sole with lighter fluid (evaporates quickly, has a low latent heat, and helps keep the stone free from pinning) to remove any raised burrs. Clean the sole with a rag and lighter fluid. Let it evaporate and give the scraped sole another rub on the refreshed blue. Scrape some more from another direction. I like to scrape from two or three directions; each in rotation.
A Norton made, 2" x 5" fine India stone is an invaluable aid. When new they're too sharp. Condition one side by rubbing it on 220 wet or dry. Be sure to clean it. Tramp abrasive is worse than scraping crumbs.
Some of you may be alarmed at using flammible stuff like lighter fluid as a cleaning agent. I can only say it's the best solvent I've found. It's flammibility is balanced by its other properties mentioned above plus the stuff I prefer, "Ronsonal" in the yellow bottles, has little propensity to rust cast iron.
There's a time element as well. Lighter fluid evaporates in seconds and doesn't carry away much heat from the work. It's a major time-saver. Lacquer thinner is harsh on the hands and has a higher latent heat. Plan on waiting up to 30 minutes for mineral spirits paint thinner to evaporate and an hour for real Stoddard solvent. Flammibility isn't a real issue in my shop. I don't smoke, I'm careful with rags, and my scraping area is well ventillated.
Water based cleaners have a high latent heat of evaporation. They cool the sole of the plane causing it to go concave - meaning as you work you'll scrape more than necessary off the heel and toe of the sole. I once used a wather based machine cleaner while scraping a 60" precision straight edge. Worked great!!! But: the next morning the straightedge had reached thermal equalibrium. My first check against the master flat showed the straight edge turned 0.0060" convex over-night. It was the cooling effect of the water based cleaner that did it. If you don't think water based cleaner won't have an effect on the scraping of a little old plane sole, try it and report back.
Proceed with scraping until all the file marks disappear and you get 4 spots per square inch. If you're careful with heat input at the final stages, and you scrape with a keen edged scraper, final flatness will be equal to the granite flat you're using. A small import flat is typically in the 0.0002" to 0.0003 range of a geometric plane.
I wouldn't suggest you lap out the scraper marks when done. For one thing there a belief that the slightly interrupted surface results in lower working friction. I believe this to be true but I have no numbers to support it except a maybe little less sweat. For another thing, a hand scraped surfacee is a bragging point and a handsome feature in its own right.
Precision scraping is a skill best learned under the guidance of a mentor but a crafty individual can discover most of the tricks for himself after getting a push in the right direction.
Oh my!
Bill Tindall, E.TN
>My energy was sapped just reading about the process. What a bargain was the $40 I spent getting a screwed up sole surface ground.
Well at least now I understand why my ill ground scraper didn't scrape. It was a good lesson. Woodworkers aren't necessarily machinists.
Taint that big a deal Bill
Forrest Addy
>I'm a machinist and for some time I specialised in machine tool rebuilding. Over the years I've hand scraped seemingly acres of machine ways, surface plates, etc. It takes a while and it's repetitive but sooner or later you get the desired results. A hand plane sole take a couple of hours depending on how crooked it is to start.
Like everything new the hassle come with accumulating everything you need then building the skill. As soon as that's done and you accomplish a few projects you'll wonder what the big deal was.
