Have a question? Ask Woody!
Another wiring question..sorta
Stuart Hough
>Is there a book or guide, written in "layman's" language, that I can get that will explain all the steps I will need to wire my garage/shop for 220-230V? I want to upgrade the electrical system and add 220v to it, for my heavier equipment. I am definitely NOT an electrician, and truth be known, I am decidedly respectful (read Scared S---less)of electricity, but don't want to pay an arm and a leg to get this done.Any and all advice will be helpful, and appreciatd.
Re: Another wiring question..sorta
>Stuart,
Do you have a friend or relative who is experienced with wiring? If you could work along beside someone for a while you might be amazed at how simple and easy it is to run wiring (and do it safely). Like my piano teacher always said, anything is easy once you know how. The hardest thing about wiring is the pain of fishing wires through the walls of an existing structure.
I'm sure there are many books and internet resources available, but I don't know of any particular one to recommend.
BTW, wiring for 220v is no more difficult or more dangerous than 110v. The biggest difference is how the wires are connected in the breaker box. And it sure is a lot simpler and easier to run 220v lines for equipment outlets than it is wiring 110v circuits for lights and switches!
"Wiring Simplified"
Joe Pack
>A handy, dandy little paperback sold at most hardware stores. When I worked part-time in a hardware store while I was going to school, my boss tossed me a copy and said "Read it when you're just standing around. Short on theory, long on "how to" and "what not to do."
Been in my library for nearly 40 years.
Rod Peterson -- Ormond Beach
>Updated, periodically, of course. It's an excellent choice.
Rod
My first one still had knob and tube in it.
Phil Joines Krum, Tx
Larry Clinton At Frankfort (Central)., Indiana
>Stuart, there is another option. I used to do a lot of wiring (professional). I would suggest you call a few electricians and ask what they would charge to advise you on how to run the wires / boxes etc., and then come in to inspect and do the actual hookup of the wires. I didn't mind doing this at all and would usually charge a minimal fee. I could be in for a half hour or so to instruct how to run the wires, then return for another hour to do the connections. The time consuming and labor intensive part is mounting the boxes and running the wire. The person usually saved about 80 to 90% of the cost by doing this, and ended up with a safe installation to code.
David Hay @ Denver
>I found the Black & Decker book 'Advanced Home Wiring' book to be helpful when I was wiring my old garage as well as my current shop. I believe they have an updated version that combines the 'Advanced' and 'Basic' books into a single one.
David
Jim Dillon
>Stuart,
I also used the book by Cauldwell (1st edition?), and the Black & Decker "Advanced Wiring" book. I found both very useful and led to the successful wiring of my garage workshop (including 14 4-tube fluorescent overheads, 24-110 outlets, 4-220v outlets, multiple 3-ways, garage door openers, garage and house subpanels etc. etc.). I figured once I had close to 800 feet of wiring just in the garage. Much to my surprise, it all worked and has for 10 years. I thought the B&D book was excellent regarding hooking up subpanels. If you are not comfortable with going it completely alone, the suggestion by Larry sounds like a good one. Good luck.
Jim
