OT: Tire question
OT: Tire question
OT: Tire question
henthorn
>I am going to pull a trailer from Texas to California with my Dodge 1500 pick up. It has twenty inch wheels. I will be trading it off once I get to California because the gas required is eating me up in Texas and it will twenty times worse in California because every thing is higher there due to the incompetent government Californians keep on electing.
The standard way to measure tread is to insert a penny in the tread and if you see all of Lincoln's head then you need new tires. You still can't see all of Lincoln's head when you measure the treads, but it is getting close. In your casual opinions would I be safe in risking the trip with the present tires. I am not holding anyone personally responsible for their opinion. It is only and opinion as I have asked for.
I really do need to save money because although I am selling a nice three bedroom, plus common room, 2 1/2 bath, 5 walk-in closets upstairs, double attached garage, landscaped lot, 8' X 10' storage building. close to everything place but will not even be able to buy a 24 wide mobile on a lot in California with what I will get for it. It is like moving to a third world country.
Thanks for your help.
Re: OT: Tire question
Re: Where & Why?
>Not to pry, Don, but where have you been looking in CA? I just sold my uncle's mobile (12x40) for 20k in the LA Hills on a rented space. While you are moving to more expensive real estate, they're having trouble almost property away out there. 'Tis a buyer's market, and if you're pulling a trailer with dollars packed, you will be a very popular fellow.
mm
Re: PS
>If you're hauling anything substantial I would not skip in the tires. Even if you skip along the southern part of NM & AZ, you've got some bumps to cross in cold weather. I wouldn't want to be pulling much with the tread you describe. Hitch & Ball or 5th wheel?
Politics aside...
Eddie Pacheco; San Jose, Ca.
>Tell us what you really feel, Don...:-) California is a tough town and it gets really tougher when you're retired. At least for me anyway.
I would also suggest getting the tires before making the trip. They will also be less expensive than having to get them in Ca.
I'm sure you've thought this through and I guess the only other thing I can say is to have a safe trip and enjoy the scenery along the way.
>What kind of trailer, does it have brakes, how many axles, what kind of load, how old are the tires?
Since trailer tires have no wear from steering forces or drive torque and don't get used as much, instead of the tread wearing out they tend to wear out from the inside and from sidewall damage. I've read recommendations to replace trailer tires every three to five years.
Trailer tires on trailers with brakes need good traction with breaking with heavy loads. The only other traction issue is the relatively low side forces on wet or icy surfaces. Even with low tread, the tires may be OK if the tires are not old AND if the trailer has two axles AND if the load is light AND if there is no abnormal wear due to trailer wheel misalignment.
BTW, some tires made specifically for trailers are made with less tread from the start so the "penny" method may not apply. Bridgstone mentions this about shallow tread on trailer tires: "Because wear is slow, a shallow tread still provides long tire life, and tends to produce even wear."
If the trailer has just one axle, I'd want very good tires on it for a cross-country trip - a blowout on a single axle trailer at highway speeds is a serious and life-threatening thing.
>Don, I'm reading this that it is the truck that has 20" tires and you are concerned about the truck tire tread, but will be trading the truck for something that gets better gas mileage in CA.
If it's the truck tires, seems there are two ways to look at it. If the trip will consume the rest of the tires, you will have to buy new ones in CA to sell the truck. If you buy them there, you probably will take a beating on the cost of the tires and you will have driven a long ways on marginal tires. OTOH, if you buy the tires before you go, you get to drive on nice new safe tires and sell whatever is left to the next fellow. So, IF you think you can make it safely to CA on the ones you have now and sell the truck without buying new ones, go for it. Otherwise, put the new ones on now.
I guess the same logic applies if it is the trailer tires, but I did not get it that you were selling the trailer.
And, if I read it wrong altogether, Never mind.
Howard Norman
>Assuming that you are talking about the tires on the truck Don I would replace them before I made the trip. You will certainly feel more comfortable on the road with new tires I think.
As far as housing in CA is concerned the market in CA is certainly depressed so you may be in a better position than you think. I realize that it is going to be much more expensive than a small town in Texas. However with a little bit of good luck it may not be as bad as you imagine. I certainly hope so.
Regards,
Howard
well nevermind - I thought you meant trailer tires
You say trading the truck....
John in New Mexico
>I assume you mean at a used car lot? Or even a new car lot? Why give them new tires? You won't get any more in trade for spending $500 on decent tires before the trip. I'm not saying you should run what you've got, but I sure would do so myself.
Now if I was planning to sell the truck used to an individual, I would probably put new tires on it, just to sweeten the deal.
mark, the reason is because my health has
henthorn
>deteriorated to the point that I am afraid I won't be able to care for my wife of 64 years. My kids, grandkids and great grandkids all live in California because they can't get enough money together to get out. They are demanding that we move to where they can be certain my wife is taken care of when/if something happens to me.
Thanks for your opinion on the tires.
From what my kids tell me
henthorn
>although real estate isn't moving much there has been very little depreciation in prices. A little 2 bed, one bath cottage rents of $1200 a month. That would eat me up in short order. My house won't bring enough to buy a 12' wide on a lot. I retired with an educator's pension 23 years ago. You won't believe what inflation has done to my spendable income in that time. The government is flat out lying when they say inflation has been averaging 2% a year. They say that because they have been lowering the quality of life in order to get it that low.
The Greatest Resource of All
>Is a loving and caring family not afraid to be one for all.
You are rich, indeed, Don. Have a safe trip.
Mark
Re: You say trading the truck....
Kevin Rabenaldt
>Someone correct me if I am wrong here, but don't forget that California will require tax on your vehicle, tags, etc. AND it is not certified for emissions in California. I do not believe you will be able to register this vehicle there. Better check that out.
Kevin
Glenn Madsen, near San Francisco
>You will be able to register the truck, but there will be a tax on it to replace the original Calif state taxation that wasn't paid when purchased. That's not a huge problem. Several hundred dollars, but not a huge problem. If you buy another car, someone, maybe you, still has to have covered that tax, and it's factored in somehow.
What I don't understand, Don, is why you'd want to trade the truck in when you got here. The folks here are buying trucks at steep discounts, and vehicles getting high miles per gallon are going at higher prices. Since your not such a young fellow, and your bride isn't feeling all that chipper, why would you be putting lots of miles on your vehicle anyway? The difference between two tanks of gas for the truck per month, at say total $140, and two tanks of gas per month at total $90 per month for a car you can get in and out of, is still just $50. And you have all the rest to consider with changing things. You have enough going on in your life right now to deal with.
Have those kids find you a place to live, and have them make sure it's close to them, and accessible to health care as well. And have the young ones come out and drive that load out to the Golden State, while you and your bride take a comfortable airplane trip. Long road trips are for younger folks, not ones just out of the hospital. You probably have a couple of grandkids that could come and help you out, and they would love to do it. Most families do. Clearing out the place in Texas is going to be hard on your wife anyway. Let some else take care of that.
Oh, and welcome to California. Really! Where do think you'll land?
According to this site
Denis Ch�nard, Orl�ans, Ont.
>http://data.bls.gov/cgi-bin/cpicalc.pl
Inflation between 1980 and 2007 averaged about 3.5% a year if you do the math.
Good luck Don, all the best,
DC
Red flags, I think.
>Most people in Ca. are too busy to even talk to their neighbors.
If your kids are having trouble getting money together to travel to Texas they may even have more trouble securing home care for you or your wife when needed.
We just went though a short term medical event here with my wife's dad (broken hip) and his insurance (Pittsburgh based) was balking at the costs and the providers here didn't want to deal with out of state insurance. He has Medicare, but a private company, something with a blue shield, was calling the shots. It was a hassle.
A few years ago we moved my mom over here had she was unhappy 'cause she lost all of her long time neighbors, doctors, etc. We tried everything to keep her happy. Now she has moved back to about 60 miles from where our original family house is. Relatives and old friends stop by to see her now. There's no place like home.
Investigate this a little more before deciding to move.
In the Lakeport/kelseyville area of Lake County
henthorn
>about 1 1/2 hours north and a little east of you.
Re: In the Lakeport/kelseyville area of Lake Count
>My dad has a place near Middletown, about 20 minutes from Lower Lake.
It's beautiful country up there, much quieter, and much less expensive than the Bay Area. There are good hospitals in the area for general care, and very good hospitals in Santa Rosa, maybe an hour south on Hwy 101. It's an area that has been popular with retirees over the years.
There are also a number of WoodCentralians in the area, including Marv, a saw guy who posts on the Handtools board.
It should warm up soon, too. Overnights in the low 30's, highs in the 50's and low 60's. Dad is planting bare root roses again today. It's funny, as he's in his 80's, that he will plant roses, but won't buy green bananas. At least, that's his joke.
Welcome to the Golden State! And get those grandkids working on getting you moved.
