>I need to cut 1/4 inch off each side of the counter top where I removed a built-in elec. range so I can slide a free standing range in the place. What is the best thing to use to cut it with and do I need to score it or something to keep from chipping the Formica?
>It is best to cut it from the botom mostly with a circular saw with a fine tooth carbide saw. If that is not possible you can cut it from the top with a down cutting saber saw blade. If you use the saber saw put some tape down where you are going to make the cut to help with the chipping. If it doesn't have a rolled backsplash it isn's to bad and if the counter top can be removed to do the work it isn't bad. Good luck.
>Do you have room to get a router in there? I would set up a straight edge along where I needed to cut and use a router with a long carbide spiral bit (downcut)
>A router will work at the front but when I get close to the back I've got to go up thru the backsplash which is against the wall. I HAVE to cut from the top as the cabinets are under it and I only need to trim a 1/4" off each side, but when I get to the back how can I go up thru the backsplash? What about a reciprocating saw? Is there any way I could use that and still control it well enough to get a fairly smooth cut?
I have had good luck using a belt sander. Put a really coarse belt on it and grind away, with the belt running downward toward the top surface if possible. Draw a line and sand right up to it.
And don't forget hand tools. With a nice sharp hand saw you can finish off the back splash in a hurry. I would plunge the was through the drywall to get room to make the stroke. Then patch the saw cut in the drywall. (With the handle of the saw "up" the cut will be below the counter top and behind the range.
Or, why not remove the countertops and cut them and then reinstall them? I recently took one of mine out and it turned out to be quicker than working around it.
>When cutting with either a reciprocating saw or a saber saw it would help prevent chipping out if you lay a strip of duct tape down and cut through that also.
>....make sure and score the cut line first. This will prevent chipping of the finish. You don't have to purchase a special tool for this. You can take anything and grind a very sharp point on it to use for a scoring tool. Scoring is glorified scratching ;-)
>Got it done. No problems and no tearout. Scored it and cut it with a saber saw , cut thru the backsplash with a recip saw right thru the drywall and cleaned up a few rough places with a belt sander. All of this was from suggestions from you guys here on the board. Many thanks to all.
>Congratulations on your success. I posted one of the responses and post often. I often wonder what happened when we don't hear from the original poster again. (Sometimes it like, "You don't suppose we got him killed do you?") Thanks for telling us.
