Moving to New House
Moving to New House
Moving to New House
David in Seattle
>We just bought a new house and everything has to be packed and moved pretty soon.
Does anyone have any advice on best ways to move the contents of a workshop without damage to tools and materials?
Re: Moving to New House
>Whutcha got?
Rob Stokes in North Vancouver
>I wrapped (newspaper) and boxed all my small stuff into boxes that weighed no more than about 20 lbs. If I was concerned about stuff sitting on top of the box in the truck I cut a piece of 1/4" plywood to fit as a stop cover (before closing the box). All voids inside the box were stuffed with paper as well so there was no movement of any kind inside it. Wrap everything - everything!!
With the larger tools, I took off anything that hung out (motor on contractors saw, fence rails, adjustment knobs/wheels etc.). The name of the game is to get everything as rectangular as possible while taking up the smallest footprint it can. I went to the Salvation Army, bought a whack of old blankets/comforters and super-wrapped all cast iron surfaces with them. Place "do not lift" and "no top loading" notes on the jointer wings. If you have a big planer (15"), place a 1/2" plywood "top" on it so they can stack on top if it if needed.
All benches etc. - knock them down as small as they will go.
Tape (well) all lumber into bundles that are easy to handle by one person. Have stickers ready to steady/even the lumber stacks inside their truck.
If you have mobile bases, leave the tools on them. If you have spare (good) casters, make a moving shuttle (or two) that's sure to fit your equipment - make sure you put a rope loop on the front of them.
If any door openings or gates are tight, remove the doors/gates and get them out of the way.
Turn on ALL the lights they could possibly need.
Remove ALL throw rugs and door mats etc. from the movers paths
If you have to run the tools across lawn or soft dirt to get them to the tuck, make a plywood road for the movers - they'll appreciate it.
But most important of all - be there! Stage the stuff in the shop for them - get it ready to go and teach them how to handle the bigger stuff. Make sure you have coffee and doughnuts an water etc. for them and let them know they're hard work is appreciated - that alone will pay off in the additional care they'll take.
Good luck!
Rob
How far? Are you doing the lifting?
Gary Camp, Bend, Oregon
>Just having done this (and having to do it again in the next 3 months). Are you moving yourself and are you moving far? I got a refridgerator dolly and rented the lowest deck trailer I could find. I used a sheet of plywood and some blocking to ramp into the trailer. I went U-haul but I think I could have done better at one other local rental places, better trailers cheaper prices, better customer service. When I move again I will buy a piece of 4 X 4 X 1/8 Angle iron about 32' long and clamp it to the existing plate on the dolly. A wider surface works better for woodworking tools.
Woodworking is a great hobby UNTIL YOU HVE TO MOVE.
glc
>It's too much trouble to move the shop contents. I suggest this is the perfect excuse for replacing everything with new! ;-)
Tom
PS...ya might want to document the condition of your stuff just in case it arrives in an "altered state".
For Instance
>If you have a cabinet saw, you might as well remove the top (rails and fence) since it will be knocked out of alignment during the move anyway. "Stationary" tools should be removed from their bases, especially anything with wheels on it, as they must not be able to roll around in the truck. Cast iron work surfaces (table saw, jointer, etc.) will do well to be bagged in plastic with a dessicant pack inside to prevent condensation and rust during the move. Your lumber should be shrink-wrapped - get several of those 12" wide hand spools at a packing supply place. Use the shrink to wrap your boxed items as well. Number each box, but don't put its contents on the outside; the contents go on your list next to the box number.
A note on lists. Have one Master List of numbered boxes for the entire house. That way you're not looking for two #23's, one for the kitchen and one for the shop, at the other end. We did this by SWMBO marking boxes she packed starting at #1, I started with the shop/studio boxes at #50. I got to #75 or so, and then she (& I) picked up numbering the "house" boxes from there. On arrival, we gave the movers copies of the Master List showing which boxes went in which room; made it easy on them when they didn't have to keep asking "So where do you want this one, Ma'am?"
Ask your mover about how they want your haz-mat handled. Finishes, solvents, and the like may have to either go in special packaging or be donated to a woodworking friend because the mover wants more to carry them that it costs to replace them. These items have some restrictions and regulations covering their transport, and you MUST tell them what you have. When I moved last time, I packed all such stuff in the car as my moving guys would not even take it.
mm
Marking things
woodenleg
>Having moved more then I care to think about, the one item I highly suggest is to label on your MASTER LIST what is in your boxes. DO NOT give that list to the movers. The one and only time I did that I came up with stuff missing from the boxes.
Dave
Re: For Instance
Stuart Johnson
Our last move had a 5 gallon bucket of used oil from my diesel packed rather high. We found out about it when one of the movers came in and told my wife they had a "little" problem. The bucket had turned over and drenched half a dozen boxes. Luckily they were filled with canning jars and other stuff that was easier to toss then try and sort out. I think we got about $200 for the damage.
This just goes to show you it pays to be there when they do both the packing and unpacking.
Re: How far? Are you doing the lifting?
David in Seattle
>We are only moving across town (from city to East Side - Kirkland). So I planned on moving some of the smaller stuff myself (hand tools and haz-mat stuff) in the car before the movers.
My main concern is the 2 cabinet saws, 18" bandsaw, lumber, planer, drill press, and jointer.
David in Seattle
>Wish I could... but don't think I'll have cash for that (putting it all in the new house).
Also, I followed the advice of many woodworkers and have only bought pretty good stuff to start with.
Geoff (in Madison)
>If you are moving your shop stuff yourself, Ryder rents trucks with lift gates which make moving them not a big deal. the won't reserve a lift gate truck (at least in Oakland), but said if you were the first 2-3 people in line at the store the morning you wanted a truck, you could get one. Penske will reserve one, but at 3X the price.
Since you are only moving locally, I would probably move my more valuable stop stuff myself. One day of your time and 2-3 trips in a rented truck will give you great piece of mind. Let the movers move your lumber. Moving the equipment yourself will keep them in alignment through the move (at least mine did).
With cabinet saws and other heavy iron don't try to do it without a liftgate truck.
Good luck,
Geoff
