material for pegs for Greene and Greene style?
Ken Platt (Granby, CT)
>Folks -
I was wondering what people are using these days to make pegs for A&C or Greene & Greene style work. Ebony is a bit pricey now, is there a cheaper alternative that looks as good? I don't need a huge amount, and will spring for the ebony if it's the best looking or is easier to use. If it matters, the piece is a bed, adapted from plans in FWW for a Greene and greene style. I am using white oak with a lot of quartersawn figure. The pegs will be purely decorative.
Thanks -
Ken
Re: material for pegs for Greene and Greene style?
Glenn Madsen, near San Francisco
>Would you need more than a couple of turning blanks for pens? My local wooddorkers' store has a selection of many dozens of these, and they are all pretty cheap, considering the rest of the cost of the build. $10 should get you more than enough, and you could get away with $2 worth, if you chose something less exotic.
What would I use? There's some bocote on my shelf that's been there for 5 years or so. I'd use that, because it's paid for already, and dark and dense. Cocobolo is in my scrap bin in small sizes. So is jarrah.
Have fun!
Bob Lang
>As Glenn noted, the small amount you use won't cost you much if you go with Ebony. On the other hand, I'm pretty frugal and use Black Walnut. I soak some steel wool in white vinegar for a few days, strain and brush on the solution and it turns the walnut black. Since you're working with oak instead of mahogany for the primary wood, nearly anything darker should look OK.
Bob Lang
