Bone or faux ivory
Bone or faux ivory
A.J. Hamler
Bone or faux ivory
A.J. Hamler
>Here's a weird one. I'd like to make some reproduction 19th-century dominoes. These were made sandwich-style -- the bottom was ebony and the top either bone or ivory. Obviously, using real ivory is out of the question, so I'd like to use bone if possible. I'd consider faux ivory if it really looks and feels like the real thing, but would prefer to use natural bone. The dimensions of the bone/ivory layer of each domino are about 1/8" x 15/16" x 1-13/16 (actually, just a hair shy of each of those dimensions), so the supplies I'd need wouldn't have to be huge; a little would go a long way.
Any ideas on a source for bone? And, as a second choice, faux ivory?
Thanks.
A.J.
Re: Bone or faux ivory
Lee Gordon
Lee Gordon
>If you were still around here you could probably go to Newington Meat and ask Vito or Paul for some bone -- and get some of their delicious chicken salad while you were at it. But you're not around here so I would suggest either a local butcher shop or even the meat counter at the supermarket. It's possible, however, that a butcher wouldn't generate a lot of scrap bone since most of the bone that comes in stays with the meat is was attached to and gets put out into the display case.
Therefore, the best place to find some big, honking boneage would probably be a local meat packing company. I assume there are a few in your vicinity. And if not, how about trying a local farmer.
Another alternative to bone would be antler. You might find some just by patrolling the woods, but that may take more time than you care to devote to antler hunting. Then again, a local sportsman who hunts for the meat, not a trophy head to mount on his wall, may have some antler to spare. Better yet, if his game of choice happens to be wild boar, the tusks are likely to be the most ivory-like substitute you could find.
Ed Mulligan, Cape Cod
>Luthiers use bone for guitar nuts and saddles.
Here's a thread from a guitar forum on the subject:
http://69.41.173.82/forums/showthread.php?t=116635&highlight=source+bone
and here's the relevant link for pre-processed bone from a pet supply company mentioned in the thread:
Redi Sterilized Natural Beef Bones - X-Large 6
There's also Tusq, a plastic material used as a bone substitute. It is made by Graph Tech but they don't carry the size you need. Maybe a special order? Another possibility is Corian.
Good luck!
Ed
Bart Goldberg
Re: Bone or faux ivory *LINK*
Bart Goldberg
>Hi - Mammoth Ivory is still available - no need to use imitation if you so desire.
Bart
Mammoth Ivory
>While it doesn't really look like ivory I think holly would be a good choice, and is readily available relatively inexpensively. If you used mamoth ivory you would want to implant a tracking device in each dominoe. About $45 for a large enough piece for a pen blank the last time I checked ;) But hey, if you can afford that it would be nice.
Lee Gordon
Lee Gordon
>I don't know. If they keep killing mammoths to get their ivory, they may go extinct. :-)
Larry Clinton At Frankfort (Central)., Indiana
>Might find an old worn out piano AJ. I had one but it went to its grave long ago. In this area there are a lot of uprights thrown out. Don't know if the keys would be wide enough though.
Dale Stansbery
>If you can't find enough bone locally, try to find an old pair of moose antlers. You'd have to figure out how to flatten the pieces, sanding I suppose. Moose antler core is less porous than deer antler, and you could probably get a whole set of dominoes from one set of antlers. There is usually moose antler listed on Ebay.
Orion
>I've found bone at the meat counter in the past although they don't usually have full leg bones. It's interesting to work with though. A little sanding up through about 600 then some brasso will make a remarkably smooth and shiny surface.
John Weber
>Check ebay for old ivory piano keys. I'm not sure if they are thick enough, but plenty of different key sets there.
Tagua Nut or Mother of Pearl
Garrett in Victoria
>is what turners use as an ivory substitute. They are inexpensive and readily available.
Another option is Mother of Pearl. If you live anywhere near the sea, picking up a few oyster shells would do the job.
Cheers, Garrett
>A.J. you can get bone already cleaned and bleached at any good pet store. I searched all over for bone and then Bonnie Klein had a lesson on cleaning and bleaching bone. I tried that and it was a pain. Then I went to the pet store to get something for the dog and there was exactly what I needed.
Tagua nut looks good and is easy to work with but very hard to find in that size.
scrimshaw suppliers *LINK*
Michael Dresdner
>It will be tough to get processed bone that size, but if you call one of the suppliers who cut bone nuts and saddles for the guitar industry they should be able to tell you if they can cut pieces to that dimension. Someone mentioned Tusq, which I think is quite convincing and the guy who makes it could certainly cast it in any size or shape you want. He does custom orders, but because Tusq was developed for its sonic properties as well, it may be more expensive than the alternatives. However, I would think one of the best, and cheapest, sources would be the folks who sell both cast 'teeth' and blanks to the scrimshaw industry. That is a synthetic polymer that looks quite a bit like ivory and machines and handles nicely. The link is a good place to start.
http://www.boonetrading.com/
Alan Young
Try the Road Kill Cafe.
Alan Young
Don Orr
>What about "Alternative Ivory". I've seen it advertised in turning magazines. It's some kind of synthetic but it's supposed to look fairly real.
A.J. Hamler
Hey, I have an idea...
A.J. Hamler
>... Next time you have possum for dinner, how 'bout making me up a doggie bag?
A.J.
A.J. Hamler
A.J. Hamler
>Actually, I've considered holly. My only concern there is that it's much lighter than either ivory or bone. Still, I'm sure many originals were made with holly or some other very-light wood.
A.J.
A.J. Hamler
Thanks!
A.J. Hamler
>Great suggestions; thanks!
Tagua nuts would work great, if I could find enough that were both long and wide enough to get 28 pieces.
I hadn't thought of pet stores, but now that you mention it, I recall seeing those big, hollow, soup-bone looking things every time I go. And, as I recall, they're already bleached to near pure-white. I may pick one up this afternoon and play around with it to see how that works, and then go back for a bag full if it does.
I did check the musical instrument Web sites, but most of the "nuts" and bridges I found weren't the right size.
I had done Google searches for "faux ivory," but never thought of Googling "alternative ivory." That turned up a source at Constantines. They have it in sheets that are 1/8" x 4" x 5", which would give me enough material for 10 dominoes, with allowance for kerf. Three sheets would give me enough for a full 28-piece set, with two extras. Still on the pricey side at $16 a sheet, but if it looks right it would certainly be the easiest way to go since the sheets are read-to-work right out of the package and are already the right thickness.
Thanks everyone!
A.J.
John McGaw
>I have turned moose antler and the samples I had were probably too porous more than 3/8" in from the surface to look right as an ivory replacement. Of course if just the surface was considered there is a lot of that and slabs could be processed pretty readily by cutting the flattest parts of the antlers into strips and then resawing those to give blanks and then using the outside surface while assembling the dominoes.
Re: Thanks!
Dan Donaldson
>I wonder about the stability of tagua nuts. I had a couple that sat in a drawer for a long time and they dried out and shrank. Not sure if this is normal, but I would try something out before I committed to using them.
Alan Young
How would you like it prepared,Finished orPlaying?
Alan Young
Re: Thanks!
Dennis Jackson
>Another possiblilty would be one of the solid surface counter tops. They come in a vast array of colors and some of them come in fairly thin sheets.
