computers
Ronald Walls
>Need to know if upgrade from 512mb DRAM to 2 G. would help speed my laptop up. Or is it a waste of $$?
computers
Ronald Walls
Ram Helps
Dustmaker Mike
>It all depends on the processor the operating system and hard drive space. Yes hard drive space if the HDD is running close to full you would be better off replacing it with a bigger one or clearing off the old stuff you never use. But as a rule of thumb Ram helps but there is a lot of other stuff that can cause a slow computer.
Re: computers
Chuck W
>What do you have for a laptop and what price is the extra memory?
Re: computers
Jay St. Peter - Southern, MD
>I've upgraded all mine and it makes a big difference. All the security crap in the MS upgrades over the last few years has really taken it's toll. I'd say for XP 1G is a minimum for reasonable performance these days.
Re: computers
Bill Howatt
>It depends on the OS and also, once you are past the just enough boundary, what you are doing with the machine. If you are editing video or even doing some still photo editing on large files, then memory will definitely help. If all you are doing is running email, browsing and maybe typing a letter then it is unlikely it will do much for you. I am writing this on a XP desktop with 512MB of RAM. I have never felt the need for more. Portable computers, especially ones a few years old, generally have slower processors and slower drives (5400 vs 7200 RPM) than desktop machines.
For most people 1GB is plenty on XP and 2GB on Vista. However,if you are going to upgrade, I'd go with the 2GB just to be done with it. Remember, if you have a slow processor more RAM won't cure that; it only fixes cases where RAM is a bottleneck.
Bill
Re: computers
Howard Norman
>It depends. I think that for most applications 1 Gig works OK with XP. Not true if you are into heavy photo or video editing however. There I think that you need 2 gigs or more.
Maybe...
ScottS
>As others have mentioned, the OS you're running and the software you use makes a big difference in the amount of RAM you need. 1 gigabyte is probably the minimum I'd recommend for Windows XP. You can use the Task Manager to figure out how much RAM you typically use.
One thing to think about before upgrading is: what seems slow? Is it launching applications? Recalculating the numbers in a huge spreadsheet? The reason I mention this is that I've found that a faster hard drive can also make a machine seem much faster. Most older laptop hard drives spin at 4200rpm. These days 5400 or even 7200rpm is typical. A faster hard drive will make programs load faster, save files faster, speed up virus scans, etc. More RAM will speed up switching between programs, rendering of complex web pages, Excel spreadsheet recalculations, etc.
Rather than upgrading to 2GB of memory, you might want to consider upgrading to 1GB and moving to a faster hard drive...
Re: computers
Denis Ch�nard, Orl�ans, Ont.
>Adding memory won't hurt, but the memory is only a bottleneck if there is less available than what your applications use. If your tray at the bottom right of the screen is loaded with icons, this means that all these applications are running at the same time, and they use memory and CPU cycles. If you don't need all of them (lots of stuff gets loaded there in a sneaky way by the software you install), removing the ones you don't need will free up memory and speed up the system.
If your drive is fragmented (if you don't know what that means it probably is), running a defragmentation tool (Diskeeper or the utility included in Windows) will help speed up the system by putting files in contiguous areas of the disk, speeding access and read times. Think of it as cleaning up your shop :-)
If the machine has become more sluggish over time, it is an indication of "OS decay", meaning that over time with software installation, upgrades/updates and de-installation, the process leaves stuff that does nothing for you yet loads up your machine. A full system re-install then will speed up your machine noticeably.
HTH,
DC
Re: computers
Glenn Madsen, near San Francisco
>Memory might help, but might not. New, quality laptops are available in the $600 range and sometimes less. And they come with warranties and dealers/manufacturers. Sometimes with faster hard disks and other goodies. It might be worth it.
On the other hand, you can try to find the right memory for that $100 upgrade that may do little for you. It's sometimes hard to get the last drop of value from an older laptop. I know. I have one that was fresh in 1999, and it's finally died. The new one in in the planning stages right now.
Re: computers
Ronald Walls
>Thanks for all the help guys. I will start with the memory then maybe a new hard drive. Thanks again
Re: computers
Dan Donaldson
>It might be a good idea to add up the price for the memory and a hard drive and compare the cost to a new computer. It might surprise you.
Re: computers
Carol - now in NC Nebraska
>Begs the question, Dan.
What's the hot ticket in laptops these days. My ol' Thinkpad is getting rather long in the tooth (as it my desktop, but it's the laptop's turn for replacement).
The Thinkpad has been a tank, and it gets lugged around a lot, taking its bumps and bangs. Would want to get another toughie.
Failing brands and models, how about gotta have features?
Re: computers
Dan Donaldson
>I don't really know much about laptops as I really don't need the portability and prefer the expandability of the desktops. I didn't intend to beg the question. Sometimes it is simply cheaper to buy new than to upgrade. Perhaps not in your case, but I would at least check it out before I put a lot of money into an old box. earlier this year I had a computer that had some weird memory in it that was quite expensive. I priced out adding some to it. (it only had 256 meg and was a dog) For the cost of adding enough to get me to 1 gig of RAM, I added a bit over $100 and got a new dual core pentium with 2 gig of RAM, DVD writer (that the old one did not have) and a 320 gig sata hard drive. To me, it just was not cost effective to upgrade the old one. As it happens, I didn't use the 320 gig drive. It had Vista on it. I played with it for a few hours, pulled out that drive, dropped in a spare 500 gig and installed Linux. ;-)
The old one still works, and I am thinking of making it into a file server which does not need a lot of ram, especially with no gui (linux server). It has 2ea 500 gig eide drives in it, so should be good for that.
