Re: OT replacing wear strip on aluminum snow shove
Jay in TX
>Hmmm... Since repair is the only option.
What exactly is dislodged? I'll assume it affects performance to not be able to use the shovel.
So,
1. Use hand-drill to remove current rivets (drill with bit that will remove the center without widening the holes).
2. Find suitable (Length, width, thickness) piece of scrap metal (probably mild steel) and fit to empty spot where wear plate used to be. You may be able to use the old wear strip to mark fastner holes for new wear strip.
3. After marking new wear strip for holes, drill them out (probably best to use the Drill Press for this) Remember you are drilling metal, not wood.
4. Fit check new piece to shovel, make adjustments if necessary
5. Fasten new wear plate to shovel using rivets or some other appropriate fastener that won't interfere with normal operations.
BTW, I've never repaired one. I've either replaced or used an old 'coal' shovel that I got from Dad(don't know if coal is right, but its big) and bought a replacement near the end of the season. And no, I'm not originally from Texas. But the mild winters have been almost as pleasant and the allergies have been unpleasant.
