The Devil's Ash
>Had been tasked to replace an ash coffee table in the game room that had been appropriated to a stand for the big screen.
Went out and bought the KD 5/4 rough, let it sit in the shop, etc. When the breadboard top (30x50) was glued up and run through the Performax, I was greeted with a fine crop of sticker stain, with lesser amounts on the structural elements of the tressel. OK, so 2-part bleach will be part of the finishing program.
Sanded down to 180 and then did my due diligence on scrap to get a "close" match to the color of the existing items. Settled on a water-sol'd Mission Brown dye, oiled with a wipe of Watco walnut, and topped with garnet shellac and a waterborne varnish.
Step 1: Bleach. Result: All's well, nice even pale cream color with no sticker stain in sight. Neutralized with white vinegar, rinsed with water, dried well and carefully sanded back to 180.
Step 2: Apply dye. Result: Disaster! Splotched and huge color variations going from brown to red to a muddy gray. Out comes the sander and the 60 grit to cut this back to raw wood.
Step 3: Sanding finished back to 180 with no scratches showing and managed to not cut through the bleached layer (now feeling proud of my sanding or bleaching ability here)
Step 4: Reformulate a stain program with other than the water dye (which went down the drain anyway). Result: Close, with several minwax pigmented stains mixed.
Step 5: Apply stain. Result: Legs and stretcher are fine, but Disaster strikes twice! The stain's pigments deftly fill all of the 60 and 80 grit RO scratches in the top that I missed with the 3+ hours of sanding (and vacuuming & sanding & vacuuming & . . ) I did.
Step 6: Make special note to have eyes checked.
Steps 7 & 8: Resand and restain, then wet-sand by hand with stain and MS slurry with 220 w-o-d. Result: By Golly by Gosh, it looks like we're getting somewhere, boys 'n girls.
Step 9: Apply the dewaxed 2lb cut garnet shellac sealer coats and get to use my X-mas present, the CA Tech. Jr. mini HVLP gun. Result: Now THAT's a nice sealer coat! No scratches, no sticker stain.
Yes-s-s-s-s-s! The table is done until, that is, the weather warms enough to apply the top coat which has to be done outside for ventilation.
This table has cost far more in time and frustration than it will ever repay, all for a game room table that will get pushed around anyway. But the thing became a pitched battle between Good and Evil, Light and Darkess, Stallone & Weathers (wilst that weenie, Formica, waited behind door #3).
But, sports fans, the combined Might of Persistence and OCD medication has, once again, triumphed, and all's well in Mudville.
[And the first putz to put his/her sandled foot on it will be shopping for a prosthesis!]
mm
