Re: Rubbing a finish out.
>Lee,
I would anticipate that what you have are dust nubbies rather than air bubbles.
I take it you want to level your film which you should do gently by hand with a block wrapped with the black wet/dry paper (320 or higher) with lubrication moving in the direction of the grain only. I use a hard rubber block.
Now a question: Do you want to recoat, or rub to final gloss?
Once you have leveled the film, wipe your surface well with paper towels and then a lint free cloth moistened with the lubricant you used (water or mineral spirits) to remove all of the sanding slurry. You can apply another coat of finish if you want more visual depth, or proceed to rub out the finish.
To rub out, start by wet sanding again with 800 grit w/d paper, again in the grain direction, and wipe dry. Next dry rub (same direction) with 0000 steelwool. Vacuum well.
SPECIAL NOTE: If you will be recoating, especially with a water-based or waterborne finish, NEVER, use steel wool. It will imbed metal fibers in the wood or grain which will either react with woor tannins or rust in the finish (or both). Use the synthetic pad material instead.
Now you can start the real rubbing. I like to use Meguires auto compounds starting with #2 Fine Cut cleaner, then #3 Machine Glaze, and if you want a float glass finish, #9 Swirl Remover. The good news is you can apply the Meguires with a power buffer; I use my RO sander fitted with a sponge head, a car waxer with also do nicely.
You can also use the more traditional rubbing compounds of powdered pumice followed by rottenstone along with a non-drying oil lube like mineral oil or "rubbing" oil. You can do these by power or by hand using a block wrapped with cloth that you change when you change grits.
Hope this helps.
