Making Plywood
Wess in NJ
>I have a project in mind where I will need a panel (probably cherry) that will be about 18" wide by 30" long. The design will have the panel captured on four sides by a frame but I need to glue it solid for strength. I know a veneer over substrate would be the obvious answer but a carving is to be done so that will not work. So, (finally) my question is, if I were to resaw some solid stock to say 1/16" thick laminations and cross the grain like plywood and then press the whole thing together would it stop the cross grain expansion?
