help with drill press
wrf
>Woe is me.
turned on my 16 1/2 inch delta drill press today and it sounded like rocks inside a cement mixer.
Worked fine a week ago.
Quill travel smooth and normal, movement of all belts and pulleys seems fine, no movement i can see at motor mounts, no obvious loose bolts or connections i can see.
Anybody have any ideas? Problem? How fix etc?
Re: help with drill press
>This is a wild guess because I haven't had my drill press apart in years . check the nut that holds the pulley onto the quill. Mine came loose once and caused some kind of problem but it's been too long to remember what it was. Seems like it was a rattle if I remember right.
Re: The problem is...
Al Stokka - Cambridge, Iowa
>...you plugged the drill press into a 220 volt oulet! Don't do that.
Plug it in to a 120 volt outlet and it'll be fine.
No, I didn't read your subsequent post. ;^)
You're welcome,
Al
WRF
>You sir are a genius. It worked just like you said it would!
>Glad I could help. ;^)
