Lacquer Temperature Resistance
Joshua Newman
>What is the maximum recommended temperature that a lacquer finished piece of wood can safely withstand w/o damaging the finish? (The wood is red birch plywood.
Joshua Newman
Re: Lacquer Temperature Resistance
Michael Dresdner
>That varies with the formulation.
Nitrocellulose lacquer contains plasticizers to make it flexible enough for wood. The higher the plasticizer level, the lower the temperature at which it will sustain damage. Many furniture lacquers will start to soften at about 180 degrees F.
Acrylic lacquers, used mostly on show cars and vintage autos, will usually tolerate substantially higher temperatures, often above 300.
