Exterior door finish
Yonak
>I'm looking for a quality stain and finish for a wooden exterior door. I'm partial to oil-base finishes for doors and especially exterior, but I'm open to all suggestions. Thanks.
Yonak
Re: Exterior door finish
john l. blue
>Sikkens has the stuff you want, probably!
Sorta wonder how good 10W30 motor oil would do if you put it on,
let it sun for a week or so, then put somethin' else on if that
don't do the trick.
Chuck Lenz
>A marine varnish is probably about as good as your going to get.
superior marine finishes would be best
Michael Stadulis in Southern NJ
>http://www.jamestowndistributors.com/userportal/search_subCategory.do?categoryName=Varnish&categoryId=36&refine=1&page=GRID
Re: superior marine finishes would be best
Steve Schoene
>I'll second what Michael has said. The real marine spar varnishes such as Interlux Schooner, Epifanes Clear Gloss, and Pettit Captain's, will dramatically outperform consumer grade "spar urethane" products from Minwax or McCloskey. This is an area where you do get what you pay for.
Jay St. Peter - SoMD
>One of my cousins in law works for an exterior millwork company that makes doors. They use Sikkens. You can see my shopshot #868 to read my difficulties using it. But, after talking to him about it, he recommends spraying it for best results. The thing about Sikkens is it remains a little bit flexible to expand/contract with weather changes. That characteristic also makes it require a different strategy for application than I'm used to. There has to be a better way, even without spraying, than I used. You get it at your local boat supply store (West marine, boats usa, etc). Be it Sikkens or some other brand, I'd start with products used by boaters.
Jay
