?Electromagnetism and copper water pipes.
Malcolm Timbers
A friend owns a building where copper water pipes are becoming eroded and the elbows, because they are rather thin, have started leaking a year and half ago. Recently, four elbows started leaking during the past month. The plumber said it is cause by eddy currents in the pipe caused by a circulation pump. The fist elbows to start leaking were over 20' from the pump but the ones that started leaking recently are near the pump.
The copper pipes run closely along heavy duty electric conduit and fuse boxes. I suspect that electromagnetism is being induced into the copper pipes causing electrolysis to etch the pipes. I suspect this because I once had to replace a straight section of water pipe in my parents home that
was etched as the result of a family friend putting a night light on a visible pipe next to the washing machine. The bulb was lit from current via the water pipe and a hot wire from the water pump to indicate if the pump was running to help prevent running the well dry.
There is another building on this property with a hot water circulation pump, but the water pipes do not run through the electric room and there have been no leaks.
So is it a matter of water induced erosion caused by the non-stop circulation of water, or electrolysis that is etching/eroding the pipes?
