Ditto
Grant Smith
>Ken,
Take a look at the nails in strip form and note that they are (usually) thicker in one dimension than the other. Further, the tips are (usually) chisel shaped.
Obviously, the nails will be more likely to bend left to right as they come out of the gun than front to rear. Therefore, hold the gun such that the gun is perpendicular to the important edge when nailing. Also note that in very hard or figured wood, or maybe the 200th odd nail, the nail will do the unexpected on its own regardless of how careful you are.
Also look at the grain in the end of the boards you are about to nail and invision the nail going through the growth rings. In most woods, the nails will tend to want to follow the rings, so situate your boards and aim the gun to compensate as much as possible.
Thicker nails will have less of a tendency to do this, though they still will.
As a side note, I have seen a 2 1/2" nail go in an apparently clear board, do a 180 and the end pop out an inch away from where it went in. If you shoot enough nails, you'll either nail yourself annually, or learn where not to put your hands.
regards,
Grant in Iowa<---with a chip in his glasses from an errant finish nail that went ballistic.
