OT Remote Start Question
Dustmaker Mike
>Ok the story goes like this. My truck strats fine and runs fine. I use the remote start feature in the morning and it works most of the time. So I started trying to figure out what was going on. When the Temp gets below ~15deg F it will not start with the remote starter . The fuel pump runs then stops and nothing. I use the key and it fires right off and runs good. So why is it when it is really cold it don't start remotely and when it is only cold it starts remotely? Any idea or how to adjust the Remote delay. It is a Ford Factory Remote. There is no book or instructions on the remote start feature. The truck is a 2004 F150 5.4 liter
Re: OT Remote Start Question
Logid sez.....
HC Sakman
>Something in the remote's receiver circuitry is temperature sensitive. If you can locate it, try to insulate it and wait for nasty weather then see what happens.
Take care Mike!
Chico...
That's "Logic" I am typing in the dark.
HC Sakman
Open Your Eyes
Dustmaker Mike
>I thought about that also until the other morning when I went outside in 8 deg weather and hit the button to see what happened. The Fuel pump came on pressurised the system then the radio inside the truck came on but the starter never spun up. It did this three time then flashed the lights ( meaning I did not start) and stoped trying. I put the key in and turned it started right away.
Rick in Colgate, Wi
>This wont fix your problem Mike but my buddy has the exact same year and model Ford truck with an after-market remote start and it does the same thing in cold weather. The remote start fails but he can always start it with the key. He thinks its battery related as the motor turns rather slowly in colder weather and has been that way since new.
