Too cold for a portable planer?
Denis Ch�nard, Orl�ans, Ont.
>I was a bit embarrassed tonight because I was selling my Delta TP400 lunchbox planer to a fellow member of our association (it was gathering dust in my garage). Went to show him that it worked fine, and it didn't, the rollers wouldn't move the wood past the cutterhead. Unplugged the machine, and the rollers were hard as stone. Now it's about 14 degrees outside, so I suspect the temperature just "froze" the urethane rollers.
Can't be wear, the planer went through 200 sf of pine two years ago, and is still on its first side of the knives. The rollers didn't feel like they had accumulated pitch on them.
Does that mean that these planers can't be used in the cold? The buyer took it anyway, but will bring it back if the problem persists. However he will be using it in a warm environment, so we suspect he'll be OK.
TIA,
DC
Re: Too cold for a portable planer?
Eddie Pacheco; San Jose, Ca.
>I don't think that the urethane material could have gotten cold enough to the point it would not work. It may be a case where the aluminum or steel housing got cold enough that contraction created bearing clearance problems, which in turn locked the shafts. I've seen that happen first hand with bronze bushing type bearings and an aluminum housing. Very embarrassing on a just to be announced product undergoing final pre-announce testing in an environmental chamber.
and to warm for polar bears....
Roger Lance in GR, Michigan
>i'm getting confused.
Terry Quiram
>Denis
That is exactly what is happening. The rollers may not be frozen but they are cold enough that there is no "bite" in them. Before I built my shop my tools were in an unheated garage and I experienced the same problem. When it warmed up the planner work just fine.
Terry
Me, too
Bruce, a MN Galoot
>my shop is my unheated garage, and I've always had problems with the planer. Not so during the rest of the year. Mine is a Delta - the first one out -- I don't know the model # and it's too cold to go look.
Bruce in frigid MN.
Re: Me, too
>That would be a 22-540... Got one of those too...
DC
Larry Clinton At Frankfort (Central)., Indiana
>Dennis, I can't really help you on this one (though I do suspect the urethane would become much harder and have less "bite" at that temperature). Reason I can't help is that I don't work well at that temperature either!. That's why when I built my shop I installed a central forced air furnace and air conditioning.:~)
I'm Not So Good In The Cold Either, Denis
>Good Evening Denis,
If truth be known, some people say I'm not so good anymore at any temp. They don't say it too loudly, lest the conversation becomne heated. Remember the old bias belted tires which developed a flat spot over night in winter? Shook out all your fillings as you drove to an early morning Dentist appointment.
George
