Plywood verticals for shelves?
>I've been asked to make a set of shelves to fit under a staircase. They would like them to be inexpensive. The shelves would be roughly a right triangle.
The depth of the shelves would be ~18". The height of the shelves would be ~78" on one side and about ~3" on the other side. The bottom shelf would be about ~50" with each shelf decreasing in width as they got nearer to the top. As these are in a "pantry" or storage area, they don't have to look pretty.
I was planning on using 3/4" poplar plywood with ~1 3/4" poplar edging for the actual shelves. I was thinking about using similar plywood for the vertical and the diagonal.
Do ya'll think I could get by with using plywood?
Re: Plywood verticals for shelves?
Brent
>I've built them that way - you might put in vertical supports between the shelves until they are around 30" wide; more than that and they are likely to sag under a heavy load (say, a lot of canned goods, etc.). You might dado the verticals a bit just to give the shelves something to bite into and "glue and screw" the joints.
My two cents.
Brent
"I can disassemble anything..."
Re: Thanks.
Sawdust Everywhere!
>JL,
Poplar plywood is fine for this project but 50" for the bottom span is too wide a span especially if you're loading up with canned goods. Even if you double up the ply 1-1/2" and add the solid 1-3/4" front, it will still sag from the weight.
It will work fine for the shorter shelves but not the bottom one.
Like Brent suggested, a middle verticle support will work best.
